GGIInterpolation
Like Tree3Likes
  • 1 Post By hjasak
  • 2 Post By hjasak
Old   July 16, 2009, 05:18
Default GGIInterpolation
Radu Mustata
r2d2 is on a distinguished road
Hi All,
I am trying to use the GGI interpolation tools to do a better job at interpolating scalar/vector fields inbetween two non-conformal patches.
I am stuck with the syntax.
Before I did,( e.g in a two mesh case setup).
label label1 = mesh1.boundaryMesh().findPatchID("patch1");
vectorField &Up1 = U1.boundaryField()[label1];
label label2 = mesh2.boundaryMesh().findPatchID("patch2");
vectorField &Up2 = U2.boundaryField()[label2];
patchToPatchInterpolation p1_to_p2
mesh1.boundaryMesh()[label1],
mesh2.boundaryMesh()[label2]
vectorField Uinterp_p1_to_P2 = p1_to_p2.faceInterpolate(Up1);
...etc (say compare with Up2...and do other stuff)
What would be the equivalent using GGIInterpolation?
It doesn´t seem to like:
GGIInterpolation p1_to_p2
vectorField Uinterp_p1_to_P2 = p1_to_p2.masterToSlave(Up1);
Thanks
Radu
r2d2 is offline   Reply With Quote
Old   January 5, 2011, 17:05
Brent Craven
brent_craven is on a distinguished road
Hi Radu,
Did you ever get this to work? I am trying to do something similar.
Thanks!
brent_craven is offline   Reply With Quote
Old   January 7, 2011, 07:20
Hrvoje Jasak
Hello Radu,
Just like in PatchToPatch, GGI has also got 2 levels:
- a template level, with the patch type as argument (capital letters)
- a typedef for patches
This allows me to do the interpolation either between stand-alone patches (which are face lists) or between boundary patches (which are slices). Thus, if you do:
ggiInterpolation p1_to_p2
it will work. Watch out for lowercase.
Hrv
hua1015 likes this.
Hrvoje Jasak
Old   January 7, 2011, 09:19
Brent Craven
Thanks for the reply - that is quite useful. Thanks, Hrv!
Brent
Old   January 11, 2011, 00:15
Default ggiInterpolation Problem
Brent Craven
Hi Hrv,
There is something wrong here. In 1.6-ext I am implementing GGI interpolation (as you suggest above) in a boundary condition as follows:
const fvMesh& neighbourMesh = db().lookupObject<fvMesh>("Mesh2");
const label& neightbourPatchID = neighbourMesh.boundaryMesh().findPatchID("iPatch") ;
const fvMesh& thisMesh = db().lookupObject<fvMesh>("Mesh1");
const label& thisPatchID = thisMesh.boundaryMesh().findPatchID("iPatch");
ggiInterpolation neighbourToThisPatch
neighbourMesh.boundaryMesh()[neightbourPatchID],
thisMesh.boundaryMesh()[thisPatchID]
Note that if I replace "ggiInterpolation" with "patchToPatchInterpolation" it works.
I have also tried the templated form of "GGIInterpolation" with no more success. For example:
GGIInterpolation<polyPatch,polyPatch> neighbourToThisPatch
Note that this also works if I replace "GGIInterpolation" with "PatchToPatchInterpolation"
Old   January 11, 2011, 04:27
Hrvoje Jasak
You are missing half of the arguments of the constructor - have a look at GGIInterpolation.H:
//- Construct from components
GGIInterpolation
const MasterPatch& masterPatch,
const SlavePatch& slavePatch,
const tensorField& forwardT,
const tensorField& reverseT,
const vectorField& forwardSep,
const scalar masterFaceNonOverlapFaceTol = 0.0,
const scalar slaveFaceNonOverlapFaceTol = 0.0,
const bool rescaleGGIWeightingFactors = true,
const quickReject reject = AABB
or the way ggiPolyPatch does it:
// Create interpolation for zones
patchToPatchPtr_ =
new ggiZoneInterpolation
zone()(),
shadow().zone()(),
forwardT(),
reverseT(),
shadow().separation(), // Slave-to-master separation. Bug fix
0, // Non-overlapping face tolerances
0, // HJ, 24/Oct/2008
true, // Rescale weighting factors. Bug fix, MB.
ggiInterpolation::AABB
I would have thought this is an obvious place to look (find-grep?).
Hrv
elvis and hua1015 like this.
Hrvoje Jasak
Old   November 14, 2011, 05:44
Peter Müller is on a distinguished road
Hello together
I try to instantiate an object of the class ggiZoneInterpolation. Until now I created a new polyPatch, called mpPolyPatch, derived from polyPatch. Inside of this mpPolyPatch I created an algorithm which is able to generate a structured mesh inside of the surrounding edges of the existing boundary patch. Based on this new vertexes and a corresponding list of faces I created an object of the class primitivePatch, called virtualPrimitivePatch.
Until here everthing works and I can see that the algorithm worked properly by using the writeVTK function and opening the two meshes with pvFoam.
I now tried to create an object of ggiZoneInterpolation with:
ggiZoneInterpolation myGgiZoneInterpolation((*this),virtualPrimitivePat ch);
But this gave me the error that there is no matching function to my call.
I'm quite new in OpenFoam. I thought ggiZoneInterpolation only needs two primitivePatches to calculate the weightings.
Thanks a lot
Peter
Peter Müller is offline   Reply With Quote
Any update on mixerGgiFvMesh jaswi OpenFOAM Running, Solving & CFD 69 April 20, 2013 13:22
