Simple heat conduction problem
Like Tree2Likes
  • 2 Post By Tobi
Old   June 13, 2009, 10:39
Default Simple heat conduction problem
Marco Bernardes
masb is on a distinguished road
Dear Coleagues,
I'm looking forward to solve a simple heat conduction problem using OpenFOAM, e.g., a bidimensional block with a temperature difference between east and west boundaries. North and south boundaries may be no heat flux condition.
I appreciate any contribution.
Regards,
Marco.
masb is offline   Reply With Quote
Old   June 13, 2009, 20:07
Pawel Sosnowski
psosnows is on a distinguished road
since I can not find heatConductionFoam, I would advise to take a look at chtMultiRegionFoam. In there, just look at the solid part: solveSolid.H, createSolidFields, etc.
You can find there everything you need and lots more
Regards,
Pawel
psosnows is offline   Reply With Quote
Old   June 13, 2009, 23:03
Marco Bernardes
Pawel,
Thanks for your help.
Regards,
Marco
Old   June 14, 2009, 06:29
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
The solver you need is laplacianFoam.
Regards,
Jose Santos
Originally Posted by masb View Post
Dear Coleagues,
Regards,
Marco.
santos is offline   Reply With Quote
Old   June 15, 2009, 16:14
Marco Bernardes
Caro José Santos,
Creio que você deve falar português. Muito obrigado pela sugestão. Eu procurei o exemplo relacionado com o solver laplacianFoam. Encontrei flange mas não consegui fazê-lo funcionar. Você poderia me ajudar com isso, por favor?
Agradeço desde já,
Marco Aurélio.
Old   June 15, 2009, 17:00
santos's Avatar
Jose Luis Santos
Hi Marco,
English is the official language of this forum, so lets stick to the rules.
What is exactly the problem you found when trying to run the flange tutorial? Have you ran the Allrun script?
Regards,
Jose Santos
Old   June 15, 2009, 21:48
Marco Bernardes
Hi Jose,
sorry for the inconveniences. I have tried to run the blockMesh command. Should I run Allrun script?
Regards,
Marco.
Old   January 11, 2015, 13:00
Mehdi Asghari
Asghari_M is on a distinguished road
Dear Colleagues,
Did you get a solution for your problem?
I have a similar discussion started in following link:
http://www.cfd-online.com/Forums/ope...n-problem.html
How can I simulate a simple conduction problem by OF.
My experience about this software is limited to cavity driven tutorial.
Thanks a lot for any suggestion.
Asghari_M is offline   Reply With Quote
Old   January 12, 2015, 08:25
Alex
zfaraday will become famous soon enough
Hi Marco,
Yes, you should run the Allrun script by typing in the terminal
./Allrun
. Otherwise you can open the file with a text editor, such as gedit, and execute manually each step on your own.
Regards,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   November 16, 2016, 11:24
inginheiro is on a distinguished road
Unfortunately with lapacianFoam you cannot specify a thermophysicalModel (for example, temperature depent thermal diffusivity). You can use chtMultiRegionFoam and just define one solid region.
Cheers
inginheiro is offline   Reply With Quote
Old   November 17, 2016, 10:53
Arrow Some remarks
  #11
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Dear all,
I just want to give you some advice for the sake of clearance. A simple heat conduction problem can be solved by using the laplacianFoam from the basic solvers (as already mentioned here). Another option is to use the chtMultiRegion solver (as mentioned too). But please keep in mind that you should know about the solvers. As inginheiro mentioned, the laplacianFoam solver can just be used for a fixed thermal conductivity. However he mentioned to switch to cht that I would not suggest. If you want (for example) to use a temperature depended field I would rather modify the laplacianFoam than using cht (if I would be a beginner) because cht can be very confusing and for a beginner, FOAM could be confusing (even if it is very simple to use).
At least some personal suggestions for all of you:
  • Always check which problem you want to solve
  • Check the easiest solver that fits your problem best
  • Check if all physical aspects can be taken into account with that solver
    - If not you have two options:
    a) Searching for a better solver which may be more complex
    b) Adapt the solver of choice to your stuff
  • Make sure that you understand the physics and mathematics and that you implement everything right
Even if you have two solids with different conductivities, I would prefer to use laplacianFoam and just modify the conductivity to an scalarField and initial it with setFields in order to have two different physical behavior in one domain rather than using cht. Of course, if you want to have some special contact boundaries it might be worth to switch directly to some cht solver. But as I said, be sure to use the solver you need.
Furthermore, I would like to have posts in which you clearly define your problem rather than just ask for a 2D conduction heat problem. As we already see, everybody is giving some own opinion and no-one knows what the thread starter really want to simulate in detail. The outcome of such things are threads with lot of single-lined replies that are annoying for people who search for an concrete answer. Furthermore, please stay to the question. Here the question was how to solve a 2D conduction problem and NOT how to use OpenFOAM or other topics that are not related to the thread. For beginners I refer to the very good new OpenFOAM Tutorial Wiki wiki.openfoam.com, the User-Guide and other sources. For most people it would be the best to sit down, open a case, and start to understand what we are doing. Finally, Linux skills for bash should be known.
New question that is not related to that thread, open a new one.
@Marco: If you can edit your Spanish reply, please translate it to English.
And now I let you discuss in any direction you want to go
Kirils and granzer like this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Convection & conduction simulation problem debashis FLUENT 1 June 26, 2009 04:45
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 16:41
radiation/ conduction problem brian jackson FLUENT 1 December 4, 2006 06:23
Heat Transfer Problem Help JB FLUENT 2 October 18, 2006 19:54
conjugate heat transfer problem Andreas CFX 1 February 5, 2002 19:22
