January 7, 2006, 14:49 |
The lnInclude directories in O
The lnInclude directories in OpenFOAM contain a set of symlinks to all of the source files in the associated directories, thus allowing one to include only lnInclude in the relevant paths rather than having to include all of several dozen (or more) actual source directories.
I would presume that these are automatically generated by a simple script of some sort. Could someone post a copy of that script? (I'm working on a basic Cygwin port of at least the core parts of OpenFOAM, which requires renaming a number of files and a couple of directories to deal with case-sensitivity problems, and thus having this script to regenerate the lnInclude directories would save me quite a lot of work!) Thanks much! |
January 7, 2006, 17:19 |
The script is wmakeLnInclude.
Hrvoje Jasak
Rep Power: 33 |
Go to the library source directory and do wmakeLnInclude . There is no good way of doing this for all the libraries in one go beucase the source is organized hierarchically and each bit takes care of itself. Good luck, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
January 8, 2006, 22:56 |
Thanks! That's exactly what I
Thanks! That's exactly what I was looking for.
January 9, 2006, 07:30 |
Maybe it will be interesting f
Maybe it will be interesting for you to follow a discussion Case-insensitive unpacking and windows/macos.
January 26, 2006, 20:02 |
Thanks Petr! That definitely
Thanks Petr! That definitely does look useful to me.
Modifying Source Files in Flow3D Directories | Xizao Yang | FLOW-3D | 3 | January 15, 2009 04:02 |
Time directories | robbo | OpenFOAM | 1 | May 21, 2008 17:49 |
OFstream doesnbt create directories or throw errors | brooksmoses | OpenFOAM | 3 | January 30, 2006 07:28 |
Modify the reconstructPar to delete the reconstructed parallel directories within the loop | maka | OpenFOAM Post-Processing | 2 | December 16, 2005 11:37 |
Modifing reconstructPar to delete the reconstructed parallel directories | maka | OpenFOAM Pre-Processing | 1 | December 13, 2005 08:16 |
