December 29, 2005, 13:01 |
Hi!
I use XEmacs to edit my
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi!
I use XEmacs to edit my source-codes. My "problem" is that the indentation-convention (Nr of spaces to indent for a new block etc) of the C++-mode is not the same as that used in the OpenFoam-sources. Therefor editing a OF-Source-file means either not using the Emacs-indentation or "messing" it up. Of course (it is Emacs we're talking about) these conventions can be customized by setting a bunch of variables. My question is the following: has anyone already done this and could she pass me these settings. thanks for listening PS: Hope I don't start a religious discussion ("Vi versus Emacs" or "XEmacs is not Emacs) here
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
December 29, 2005, 13:39 |
Sure. Please send me an E-mai
Hrvoje Jasak
Rep Power: 33 |
Sure. Please send me an E-mail and I'll pass you the relevant sections of the .xemacs file. It is not perfect, but it's pretty good.
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
December 29, 2005, 15:25 |
For those interested: The cust
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
For those interested: The customizations provided by Hrv can now be found at
http://openfoamwiki.net/index.php/HowTo_xemacsInd entation (the code is Hrv's, the errors are mine)
January 27, 2006, 10:25 |
Cool !
I will try it ...
I
Francois Beaubert
Rep Power: 17 |
Cool !
I will try it ... Is there any vim or jedit gurus that can do the same for vim and/or Jedit I've found this link on the web: Ident Finder http://phil.freehackers.org/indent-finder/ Description ------------ Indent Finder is a python script that reads a file and tells you what indentation is used inside the file. The indentation analysis works on any language. It was tested successfully with C, C++, python and Java code. The current version provides helps for the integration with vim. Maybe I will be helpfull |
February 1, 2006, 05:27 |
For the nedit users among us:
Mattijs Janssens
Rep Power: 26 |
For the nedit users among us: set up all files ending in *Dict to be c++ syntax. (in addition to *.C and *.H ofcourse)
