Error with diffusivity Keyword in dynamicMeshDict Using displacementLaplacian
Like Tree1Likes
  • 1 Post By Krapf
Old   October 26, 2024, 18:21
Exclamation Error with diffusivity Keyword in dynamicMeshDict Using displacementLaplacian
Azad
azad_786 is on a distinguished road
Hello OpenFOAM Community,
I am working on implementing dynamic mesh motion for a case in OpenFOAM-extend 4.0.
My objective is to enable displacement-based mesh adjustments using displacementLaplacian with dynamicMotionSolverFvMesh.
However, I have been encountering persistent issues, particularly with configuring diffusivity in the dynamicMeshDict file.
Implementation Strategy:
Solver Modification: My setup involves modifying the solver to handle dynamic mesh operations, specifically by applying dynamicFvMesh (later extending to dynamicMotionSolverFvMesh). solver compiles
Mesh Motion Solver: I have e selected displacementLaplacian as the motion solver within dynamicMotionSolverFvMesh to manage displacement-based mesh modifications.
ERROR:
Create dynamic mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: displacementLaplacian
--> FOAM FATAL IO ERROR:
keyword diffusivity is undefined in dictionary "/home/app/foam/app-4.0/sharedRun/foamcases/mesh_moving_directional/1_planar_case/constant/dynamicMeshDict"
file: /home/app/foam/app-4.0/sharedRun/foamcases/mesh_moving_directional/1_planar_case/constant/dynamicMeshDict"t from line 11 to line 24.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 395.
FOAM exiting
my constant/dynamicmeshdict file looks like this
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object dynamicMeshDict;
// Load the necessary library
libs ("libfvMotionSolvers.so");
// Specify the type of dynamic mesh
dynamicFvMesh dynamicMotionSolverFvMesh;
// Define the solver type
solver displacementLaplacian;
// Define the coefficients for the dynamic motion solver
dynamicMotionSolverFvMeshCoeffs
displacementLaplacianCoeffs
diffusivity uniform 1.0;
and 0/pointDisplacement;
FoamFile
version 2.0;
format ascii;
class pointVectorField;
location "0";
object pointDisplacement;
dimensions [0 1 0 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
left
type fixedValue;
value uniform (0 0 0); // Fixed boundary with no movement
right
type uniformFixedValue;
uniformValue (4e-8 0 0); // Uniform displacement on the right boundary
up
type zeroGradient;
down
type zeroGradient;
frontAndBack
type empty;
If anyone has experience with configuring displacementLaplacian for dynamic mesh motion, please advice to fix this error.
Thank you
azad_786 is offline   Reply With Quote
Old   October 27, 2024, 05:47
Krapf is on a distinguished road
The error message indicates that you are defining “diffusivity” in the wrong place. It does not belong in the "dynamicMotionSolverFvMeshCoeffs"/"displacementLaplacianCoeffs" subdictionary, but on the first level, like “dynamicFvMesh” and “solver”, for example. See also: https://github.com/Unofficial-Extend...icMeshDict#L23.
azad_786 likes this.
Krapf is offline   Reply With Quote
Old   October 27, 2024, 08:18
Azad
Thank you so much. It worked
dynamicmeshdict, dynamicmotionsolverfvmesh, foamextend-4.0, openfoam
[mesh manipulation] custom Diffusivity in dynamicMeshDict rangure OpenFOAM Meshing & Mesh Conversion 0 June 19, 2023 19:17
dynamicMeshDict diffusivity zhxter OpenFOAM Programming & Development 7 May 21, 2020 11:09
Disable Mass Diffusivity and Enable UDS Diffusivity antoinel FLUENT 0 July 26, 2017 18:27
Diffusivity model in dynamicMeshDict of movingCone xuezhj OpenFOAM Running, Solving & CFD 0 October 2, 2012 23:11
GGI dynamicMeshDict keyword 'direction' lordvon OpenFOAM Running, Solving & CFD 0 April 14, 2012 21:31
