Does decomposition work with empty boundary condition? |
October 14, 2024, 13:53 |
Aykut Gunhan
Rep Power: 3 |
Hello All,
For my study, I am running a porous media in OpenFoam v2306. To save some computational cost I want to run it in 2D. I set my front and back as patch at the beginning then I run blockMesh> snappyHexMesh -overwrite > extrudeMesh (front/back) > createPatch (front/back as empty). But after creating the mesh I can check it on paraview. When I try to do decomposition I get error. Does decomposition work with empty boundary conditions? The error looks like this; --> FOAM FATAL IO ERROR: (openfoam-2306) Size 179028 is not equal to the expected length 41418 file: 0/cellLevel.internalField at line 21. From void Foam::Field<Type>::assign(const Foam::entry&, Foam::label) [with Type = double; Foam::label = int] in file ./src/OpenFOAM/lnInclude/Field.C at line 253. FOAM exiting Hint: I set the front and back as patch and named them as front1/back1 then using the createpatchdict named them front/back. Thank you in advance. %------------------SOLVED-----------% For those who encounter the same problem. The issue was the created mesh files in "0" file. After running all the steps I restored the "0" file and I was able to run the simulation without any error. cp -r 0.orig/ 0 blockMesh snappyHexMesh -overwrite topoSet extrudeMesh createPatch -overwrite # Restore initial conditions in the 0 directory restore0Dir # Decompose the domain for parallel processing decomposePar # Run the simulation in parallel mpirun -n 14 pimpleFoam >> log.pimpleFoam -parallel Last edited by agunhan; October 14, 2024 at 16:48. |
October 15, 2024, 04:52 |
Yann
Rep Power: 29 |
you don't need createPatch in your case, changeDictionary will be enough. (you don't need to create new patches, just to update the patch type for front and back) This being said, this is not the cause of your error. Code:
--> FOAM FATAL IO ERROR: (openfoam-2306) Size 179028 is not equal to the expected length 41418 file: 0/cellLevel.internalField at line 21. cellLevel is a variable written by snappyHexMesh when you have some writeFlags activated in snappyHexMeshDict. After running snappy and writing cellLevel variable, you modified your mesh with extrudeMesh, this is why you get this error. (cellLevel size does not match the size of your mesh anymore) Just remove the variables written by snappy before decomposing your case and you should be fine. |
October 15, 2024, 05:21 |
#3 | |
Aykut Gunhan
Rep Power: 3 |
Thank you, I will try it also without creatingpatch!! |
decomposepardict, decomposition, openfoamv2306 |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Question about different kinds of Boundaries and Boundary Conditions | granzer | Main CFD Forum | 17 | April 12, 2022 18:27 |
[Other] empty boundary condition | Ahmed Khattab | OpenFOAM Meshing & Mesh Conversion | 1 | December 29, 2017 10:21 |
[snappyHexMesh] sHM quality of multi-region | aminem | OpenFOAM Meshing & Mesh Conversion | 0 | April 16, 2015 12:38 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 07:49 |
