plateHole Tutorial Error
Like Tree1Likes
  • 1 Post By AllOutOfNames
Old   August 20, 2024, 09:14
Exclamation plateHole Tutorial Error
Mike
AllOutOfNames is on a distinguished road
Hi all,
I have been having error issues with using the plateHole tutorial in OpenFoam. I am new to OpenFoam in general and have tried troubleshooting. The error is :
FOAM FATAL ERROR: (openfoam-2312 patch=240220)
cannot find file "/home/alloutofnames/OpenFoam-Tests/tutorial/plateHole/0/D"
I believe that foam is not able to find the constant D file as it says, however the file exists there and has the correct information in it. I then tried to fix the polymesh folder (I read that this was the reason) and it didn't change it. I am not using snapphexmash only the standard blockMesh.
If anyone could help it would be great
AllOutOfNames is offline   Reply With Quote
Old   August 20, 2024, 13:01
Tobermory will become famous soon enough
Can I just correct the initial part of your post:
... it is actually complaining that file
doesn't exist, i.e. D in time folder 0, not constant ... probably just a typo on your part. So, assuming that when you say
I assume that you mean the file exists in folder 0? In fact, perhaps you could try typing the following lines from your case folder and let us know the output from each line:
pwd
ls 0.orig
ls 0
ls -l /home/alloutofnames/OpenFoam-Tests/tutorial/plateHole/0/D
Tobermory is offline   Reply With Quote
Old   August 21, 2024, 06:46
Mike
Hi
Thank you so much I didn't understand what was going wrong (very new to it all) but your comment made me realize the error
All the information for the D was contained in 0.orig, so I renamed 0.orig to 0 and it ran as normal. Just error in naming so the solidDisplacementFoam was confused.
Thanks for the help, have a great day!
Tobermory likes this.
Old   August 21, 2024, 07:02
I thought it might be something like that - well done in figuring it out!
help for a newbie, platehole, troubleshoot
Gmsh reports an OpenCascade exception when opening a .geo file algc Main CFD Forum 2 October 24, 2022 06:59
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 14:46
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
