Reg Command chtMultiRegionSimpleFoam in OpenFoam12 |
BabuG
Rep Power: 2 ![]() |
Hello Preers,
I installed OpenFoam 12 in WSL and also in Ubuntu 24.04 I was simulating a CHT case in transient mode using command : chtMultiRegionFoam. However, I would like to launch the same case in steady state mode and trying to use command: chtMultiRefionSimplefoam. However, I get error Command 'chtMultiRegionSimpleFoam' not found. Is it a bug or am I using a wrong command to launch the simulation in steady state mode. Kindly help. Thank you |
cht problem, steady and unsteady state |
Reg. BICGSTAB | sandy | Main CFD Forum | 37 | June 24, 2008 10:25 |
URGENT HELP REG UDF | Nag | FLUENT | 1 | February 5, 2008 19:40 |
Reg - Solve problem in Gasifier | S.SIVAKUMAR | FLUENT | 1 | October 12, 2005 02:55 |
reg .es-ice | anand | Siemens | 0 | May 12, 2005 08:27 |
reg. ES - ICE | anand | Main CFD Forum | 0 | May 12, 2005 07:42 |
