[OpwnFOAM] How do I set the "distance" in "nearWallFields"? |
July 19, 2024, 04:31 |
Rep Power: 3 |
I want to use nearWallFields to find the flow velocity at a distance of 0.01 from the model (fish) surface.
However, the settings may have failed, and the velocities for the entire analysis case were saved instead of the specified location. The save location is in the result file for each second. The following is a description of nearWallFields in "controlDict". nearWallFields { // Mandatory entries (unmodifiable) type nearWallFields; libs ("libfieldFunctionObjects.so"); fields ( (U U_nearWall) ); patches (fish); distance 0.01; // Optional (inherited) entries region region0; enabled true; log true; timeStart 0; timeEnd 100000; executeControl timeStep; executeInterval 1; writeControl adjustableRunTime; writeInterval 0.01; } |
July 19, 2024, 06:25 |
Yann
Rep Power: 27 |
The output of the nearWallFields function object is a volume field, so it is normal to get a whole velocity field. (https://doc.openfoam.com/2306/tools/...earWallFields/) The only difference is that you will get the near-wall velocity values on your walls instead of 0. In ParaView, load your model surface patches, and display U_nearWall on it to see the velocity values at the distance your specified. Regards, Yann |
July 19, 2024, 07:46 |
Rep Power: 3 |
Hello
Thank you very much. I now have a better understanding of "nearWallFields". |
ParaFoam not responding on mac | Abhisek | OpenFOAM | 0 | May 7, 2022 12:15 |
Can you please confirm that I have set up the simulation conditions correctly? | dhehdxhdaus | CFX | 3 | April 26, 2022 23:26 |
Using gnuplot to plot probe data | Rotidpor | OpenFOAM | 3 | March 9, 2022 05:44 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
