time step not being adjusted according to predefined max allowed Courant number |
June 12, 2024, 06:53 |
Rep Power: 2 |
Hello everyone,
this is a newbie's question, but I took the pitzDaily (LES/pisoFoam) example to try the adjustable time step, however it looks like it the time step is not being calculated to satisfy the maxCo I defined. I attached my controlDict here. I was going through the code and I saw that writeInterval can interfere with the code updating the time step, so I tried different values (1e3 to 1e-10) and nothing seems to change the results. PS: everything else is from the pitzDaily case, I just changed the controlDict. Last edited by ncl94; June 12, 2024 at 10:56. Reason: grammar mistake |
June 12, 2024, 07:11 |
sebastiaan bors
Rep Power: 8 |
I don't see anything obviously wrong, could you perhaps provide a piece of your log file? Do you really want to write results with each 10^-10 seconds? And do you expect the required time step for co<1 to be lower than that?
June 12, 2024, 10:54 |
#3 | ||
Rep Power: 2 |
Lower than the deltaT I specified in controlDict?Yes. Sorry for not attaching the log file instead of just writing it here, but I am getting a weird message whenever I try to attach any kind of file. Anyway, there it is: -------------------------------------------------------------------------------------------------------------------- Time = 2e-05 Courant Number mean: 0.000174979 max: 0.0631777 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 2.48998e-07, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 2.6611e-07, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0982953, No Iterations 20 time step continuity errors : sum local = 3.44036e-05, global = -1.90151e-06, cumulative = -1.90151e-06 GAMG: Solving for p, Initial residual = 0.0123119, Final residual = 6.67732e-07, No Iterations 8 time step continuity errors : sum local = 2.62174e-08, global = -2.66804e-09, cumulative = -1.90418e-06 smoothSolver: Solving for k, Initial residual = 0.72442, Final residual = 1.51991e-07, No Iterations 3 bounding k, min: 0 max: 0.000841637 average: 1.64512e-07 ExecutionTime = 0.18 s ClockTime = 0 s fieldAverage fieldAverage1: Reading/initialising field UMean Reading/initialising field pMean Reading/initialising field UPrime2Mean Reading/initialising field pPrime2Mean fieldAverage fieldAverage1 write: Calculating averages Writing average fields scalarTransport execute: s smoothSolver: Solving for s, Initial residual = 1, Final residual = 8.10247e-06, No Iterations 2 scalarTransport write: scalarTransport s Time = 4e-05 Courant Number mean: 0.0848829 max: 1.89314 smoothSolver: Solving for Ux, Initial residual = 0.858153, Final residual = 4.38444e-06, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.220983, Final residual = 8.45497e-06, No Iterations 4 GAMG: Solving for p, Initial residual = 0.0194081, Final residual = 0.00176716, No Iterations 19 time step continuity errors : sum local = 4.63307e-05, global = -3.7076e-06, cumulative = -5.61177e-06 GAMG: Solving for p, Initial residual = 0.0408878, Final residual = 5.63238e-07, No Iterations 12 time step continuity errors : sum local = 7.69652e-09, global = -1.03697e-09, cumulative = -5.61281e-06 smoothSolver: Solving for k, Initial residual = 0.239396, Final residual = 1.8275e-06, No Iterations 2 bounding k, min: -3.38517e-10 max: 0.00153181 average: 3.74304e-07 ExecutionTime = 0.24 s ClockTime = 0 s fieldAverage fieldAverage1 write: Calculating averages Writing average fields scalarTransport execute: s smoothSolver: Solving for s, Initial residual = 0.210501, Final residual = 3.31326e-06, No Iterations 2 scalarTransport write: scalarTransport s Time = 6e-05 Courant Number mean: 0.0848805 max: 1.84028 smoothSolver: Solving for Ux, Initial residual = 0.685705, Final residual = 3.32903e-06, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.0878103, Final residual = 4.38787e-06, No Iterations 4 GAMG: Solving for p, Initial residual = 0.017978, Final residual = 0.00174891, No Iterations 17 time step continuity errors : sum local = 2.27482e-05, global = 2.11883e-06, cumulative = -3.49398e-06 GAMG: Solving for p, Initial residual = 0.583057, Final residual = 5.26689e-07, No Iterations 16 time step continuity errors : sum local = 1.70612e-10, global = 2.06454e-11, cumulative = -3.49396e-06 smoothSolver: Solving for k, Initial residual = 0.146676, Final residual = 6.81688e-06, No Iterations 4 bounding k, min: -1.50636e-07 max: 0.00217707 average: 6.33037e-07 ExecutionTime = 0.3 s ClockTime = 0 s fieldAverage fieldAverage1 write: Calculating averages Writing average fields scalarTransport execute: s smoothSolver: Solving for s, Initial residual = 0.117555, Final residual = 3.4525e-06, No Iterations 2 scalarTransport write: scalarTransport s Time = 8e-05 Courant Number mean: 0.0847656 max: 1.76053 smoothSolver: Solving for Ux, Initial residual = 0.00879533, Final residual = 3.64488e-06, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.0023919, Final residual = 4.50489e-06, No Iterations 3 GAMG: Solving for p, Initial residual = 0.176207, Final residual = 0.0133852, No Iterations 2 time step continuity errors : sum local = 3.1426e-06, global = 7.29022e-08, cumulative = -3.42106e-06 GAMG: Solving for p, Initial residual = 0.0224733, Final residual = 3.64068e-07, No Iterations 11 time step continuity errors : sum local = 8.04213e-11, global = -1.0749e-11, cumulative = -3.42107e-06 smoothSolver: Solving for k, Initial residual = 0.105586, Final residual = 1.8306e-06, No Iterations 6 bounding k, min: -3.3322e-07 max: 0.0027276 average: 1.0776e-06 ExecutionTime = 0.35 s ClockTime = 0 s fieldAverage fieldAverage1 write: Calculating averages Writing average fields scalarTransport execute: s smoothSolver: Solving for s, Initial residual = 0.0814703, Final residual = 4.10346e-06, No Iterations 2 scalarTransport write: scalarTransport s Time = 0.0001 Courant Number mean: 0.0845884 max: 1.69682 smoothSolver: Solving for Ux, Initial residual = 0.00879353, Final residual = 2.88955e-06, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.00173623, Final residual = 3.72738e-06, No Iterations 3 GAMG: Solving for p, Initial residual = 0.109361, Final residual = 0.0054413, No Iterations 3 time step continuity errors : sum local = 1.09907e-06, global = -1.89206e-07, cumulative = -3.61027e-06 GAMG: Solving for p, Initial residual = 0.010983, Final residual = 6.11753e-07, No Iterations 11 time step continuity errors : sum local = 1.07575e-10, global = 7.201e-12, cumulative = -3.61027e-06 smoothSolver: Solving for k, Initial residual = 0.0849395, Final residual = 1.70522e-06, No Iterations 6 bounding k, min: -1.55854e-08 max: 0.00357542 average: 1.99527e-06 ExecutionTime = 0.4 s ClockTime = 0 s fieldAverage fieldAverage1 write: Calculating averages Writing average fields scalarTransport execute: s smoothSolver: Solving for s, Initial residual = 0.062312, Final residual = 5.05917e-06, No Iterations 2 scalarTransport write: scalarTransport s Time = 0.00012 Courant Number mean: 0.0844443 max: 1.64538 smoothSolver: Solving for Ux, Initial residual = 0.00625174, Final residual = 2.99884e-06, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.00145455, Final residual = 3.65718e-06, No Iterations 3 GAMG: Solving for p, Initial residual = 0.109404, Final residual = 0.00763556, No Iterations 8 time step continuity errors : sum local = 1.25652e-06, global = -1.08833e-07, cumulative = -3.7191e-06 GAMG: Solving for p, Initial residual = 0.0157532, Final residual = 4.27e-07, No Iterations 12 time step continuity errors : sum local = 8.47843e-11, global = -1.50146e-11, cumulative = -3.71911e-06 smoothSolver: Solving for k, Initial residual = 0.0603562, Final residual = 8.98367e-06, No Iterations 5 bounding k, min: -7.64728e-06 max: 0.00549997 average: 3.30318e-06 ExecutionTime = 0.46 s ClockTime = 0 s |
June 13, 2024, 04:00 |
sebastiaan bors
Rep Power: 8 |
My mistake, I forgot that pisoFoam does not support an adjustable time step. You could try pimpleFoam as an alternative. Or if you feel comfortable you could adapt and recompile pisoFoam (see Using adjustableTimeStep in pisoFoam), however I would suggest using pimpleFoam regardless if you intend to operate near the CFL~1 condition as you might need outer iterations for stability (depends highly on the application).
June 13, 2024, 04:07 |
sebastiaan bors
Rep Power: 8 |
You migth be interested in this reply by Tobi on configuring pimpleFoam with respect to pisoFoam.
June 13, 2024, 06:10 |
Rep Power: 2 |
Thank you very much, Sebastiaan! I didn't know either that some solvers do not offer time step adjustment, I thought it was inherited by every solver.
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
