Error Message while running propeller tutorial case
Like Tree1Likes
  • 1 Post By LongGe
Old   August 25, 2023, 01:54
Exclamation Error Message while running propeller tutorial case
kazzy is on a distinguished road
OpenFOAM-v2206
I am trying to run the $FOAM_TUTORIALS/incompressible/pimpleFoam/RAS/propeller tutorial case using kOmegaSST turbulence model.
I have followed the below steps in sequential manner:
blockMesh
checkMesh
surfaceFeatureExtract
decomposePar
mpirun -np 4 snappyHexMesh -overwrite -parallel | tee log.snappy
reconstructParMesh -constant
rm -r processor*
topoSet -dict system/createInletOutletSets.topoSetDict
createPatch -overwrite
cp -r 0.orig/ 0
decomposePar
mpirun -np 4 pimpleFoam -parallel | tee log.pimpleFoam
Post this while the case is running using pimpleFoam I am getting the below error message in terminal:
--> FOAM FATAL IO ERROR: (openfoam-2206)
Entry 'method' not found in dictionary "/home/ttdesign/OpenFOAM/ttdesign-v2206/run/sample_cases/trial/trial-propeller/propeller_case1/system/fvSchemes.wallDist"
file: system/fvSchemes.wallDist
From bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType:ption, bool) const [with T = Foam::word]
in file /home/ttdesign/OpenFOAM/OpenFOAM-v2206/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 322.
FOAM parallel run exiting
Please if you can suggest me further on this. I would really appreciate & thanks in advance.
kazzy is offline   Reply With Quote
Old   August 25, 2023, 03:16
Tatsuya Shimizu
LongGe is on a distinguished road
Hello
How about adding the following dictionary to system/fvSchemes?
wallDist
method meshWave;
kazzy likes this.
Our Work: https://www.idaj.co.jp/product/ennovacfd/openfoam_gui/
Powered by Ennova : https://ennova-cfd.com/
Ennova's Channel Partners : http://www.wolfdynamics.com/
LongGe is offline   Reply With Quote
Old   September 5, 2023, 03:07
Default Error Message while running propeller tutorial case
| \\ / O peration | Version: v2206 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) cellLimited Gauss linear 1;
divSchemes
default none;
div(phi,U) Gauss linearUpwind grad(U);
turbulence Gauss upwind;
div(phi,k) $turbulence;
div(phi,epsilon) $turbulence;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear limited corrected 0.33;
interpolationSchemes
default linear;
snGradSchemes
default limited corrected 0.33;
wallDist
method meshWave;
I have made changes to the fvSchemes file as above.
Old   September 5, 2023, 03:18
After making changes to the fvSchemes, when running the command- "mpirun -np 4 snappyHexMesh -overwrite -parallel | tee log.snappy"
I am getting the following error message:
Create time
Create mesh for time = 0
Read mesh in = 0.01 s
Overall mesh bounding box : (-0.3 -0.81 -0.3) (0.3 0.21 0.3)
Relative tolerance : 1e-06
Absolute matching distance : 1.3268e-06
[0]
[0]
[0] --> FOAM FATAL ERROR: (openfoam-2206)
[0] Cannot find surface starting from "/home/ttdesign/OpenFOAM/ttdesign-v2206/run/sample_cases/trial/trial-propeller/propeller_case2/processor0/constant/triSurface/propellerTip.obj.gz"
[0]
[0]
[0] From static Foam::fileName Foam::fileFormats::surfaceFormatsCore::checkFile(c onst Foam::IOobject&, const Foam::dictionary&, bool)
[0] in file surfaceFormats/surfaceFormatsCore.C at line 314.
[0]
[0]
[1]
[1]
[1] --> FOAM FATAL ERROR: (openfoam-2206)
[1] Cannot find surface starting from "/home/ttdesign/OpenFOAM/ttdesign-v2206/run/sample_cases/trial/trial-propeller/propeller_case2/processor1/constant/triSurface/propellerTip.obj.gz"
[1]
[1]
[1] From static Foam::fileName Foam::fileFormats::surfaceFormatsCore::checkFile(c onst Foam::IOobject&, const Foam::dictionary&, bool)
[1] in file surfaceFormats/surfaceFormatsCore.C at line 314.
[1]
[1]
[2]
[2]
[2] --> FOAM FATAL ERROR: (openfoam-2206)
[2] Cannot find surface starting from "/home/ttdesign/OpenFOAM/ttdesign-v2206/run/sample_cases/trial/trial-propeller/propeller_case2/processor2/constant/triSurface/propellerTip.obj.gz"
[2]
[2]
[2] From static Foam::fileName Foam::fileFormats::surfaceFormatsCore::checkFile(c onst Foam::IOobject&, const Foam::dictionary&, bool)
[2] in file surfaceFormats/surfaceFormatsCore.C at line 314.
[2]
[2]
[3]
[3]
[3] --> FOAM FATAL ERROR: (openfoam-2206)
[3] Cannot find surface starting from "/home/ttdesign/OpenFOAM/ttdesign-v2206/run/sample_cases/trial/trial-propeller/propeller_case2/processor3/constant/triSurface/propellerTip.obj.gz"
[3]
[3]
[3] From static Foam::fileName Foam::fileFormats::surfaceFormatsCore::checkFile(c onst Foam::IOobject&, const Foam::dictionary&, bool)
[3] in file surfaceFormats/surfaceFormatsCore.C at line 314.
[3]
[3]
MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[ttdesign:04784] 3 more processes have sent help message help-mpi-api.txt / mpi-abort
[ttdesign:04784] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
incompressible flow, pimplefoam
[solids4Foam] HronTurekFsi3 Laminar Tutorial not running parallel using Foam-Extend 4.1? EternalSeekerX OpenFOAM CC Toolkits for Fluid-Structure Interaction 0 May 29, 2020 04:12
Error problem while running sadia d lts tutorial kane OpenFOAM Running, Solving & CFD 2 May 26, 2018 04:38
Running propeller tutorial !! S.E. Kwon OpenFOAM Running, Solving & CFD 0 October 27, 2014 23:01
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
How to save a case running in background us FLUENT 0 July 6, 2005 11:43
