High resolution block within a block mesh
Like Tree1Likes
  • 1 Post By JoostLinthorst
Old   September 15, 2022, 10:11
Default High resolution block within a block mesh
Joost Linthorst
JoostLinthorst is on a distinguished road
Hey all,
So I need to have a high resolution zone inside a larger area. I have tried many different methods and have finally arrived to a method that works, but I'm getting a lot of mesh errors and warnings. I was wondering if anyone has a good method for creating this type of high resolution zone within a block mesh.
My current approach is to create multiple blocks and use mergePatchPairs to "glue" them together.
I have also used refineMesh, but refineMesh only doubles the resolution and I would like to have an even higher resolution zone than double the resolution.
Thanks in advance, my blockMesh is attached.
Last edited by JoostLinthorst; September 15, 2022 at 10:14. Reason: BlockMeshDict didn't attach
JoostLinthorst is offline   Reply With Quote
Old   September 15, 2022, 10:40
Default SnappyHexMesh
Joost Linthorst
Using snappyHexMesh's refinementBox works like a charm.
ashishmagar600 likes this.
blockmesh, refine mesh, resolution
A high order curvilinear mesh generation(converting) tool is strongly recommended hyperman Main CFD Forum 2 August 7, 2018 18:30
A high order curvilinear mesh generation(converting) tool is strongly recommended! hyperman Mesh Generation & Pre-Processing 0 June 22, 2018 09:04
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Mesh Resolution to resolve turbulent boundary layer tongx051 FLUENT 1 October 22, 2013 01:18
high mesh resolution causing vortex pimpleFoam mvoss OpenFOAM Running, Solving & CFD 2 March 8, 2012 08:06
