Setup for buoyantBoussinesqPimpleFoam with openings
Like Tree1Likes
  • 1 Post By SadBoySquad
Old   August 4, 2022, 12:54
Default Setup for buoyantBoussinesqPimpleFoam with openings
SadBoySquad is on a distinguished road
Greetings to all people in this forum!
I have trouble setting up and successfully running a simulation using buoyantBoussinesqPimpleFoam.
Unfortunately, the case does not exactly match with any tutorial.
So there's the possibility of me messing up BCs or other parameters.
Case setup:
The setup is pretty basic: a simple "building like" box structure that is heated on the top wall.
The heating part can be achieved either via a fixedValue temperature BC or via a specified heatFlux (via fixedGradient BC).
Let's assume fixedValue here, for simplicity.
The top wall is set to a temperature that is 50 degrees higher than the reference temperature.
There are four openings that flow can enter/exit based on buoyant currents.
The other walls are solid and adiabatic.
I attached some images for better understanding:
- red colored patch is solid adiabatic wall
- pink colored patch is the top solid wall that gets heated
- the bottom wall (not visible in attachments) is also solid and adiabatic for now
- all other patches are openings; I expect flow to both enter and exit
Gravity direction is towards negative Z.
What I expect:
Since the top wall gets heated, temperature in the vicinity of the wall will increase.
Warm currents will rise up and air will try to exit from the top openings.
Each of the top openings may have regions of inflow and outflow, depending on the case.
It is, of course, not 100% certain that flow will be exiting from the whole patch surface.
However, I am expecting flow to exit from the top of the patch and enter from the bottom of the patch.
Meanwhile, since air is driven up towards the warm wall, flow will enter from the bottom openings.
Is my understanding flawed?
Should I expect something different?
My problem:
I cannot seem to understand how to properly setup the case.
The case runs and does not diverge.
However, I get unrealistic velocity values.
For said temperature difference, I get velocity values that reach 50 m/s!
This is not logical.
In the attachments you can see the velocity field and its unreasonably high values.
In addition, I attached the X velocity on the patches.
Flow exits from the lower openings.
Flow enters from the upper region of the upper openings and exits from the lower region.
This is the exact opposite to what I was expecting.
What am I doing wrong?
Case setup:
Here is a link with the whole setup, in case anyone is interested to try the case.
No need to let the simulation run for too long.
100-200 iterations are enough to produce the high velocity values.
https://www.dropbox.com/s/9dme0rg8cg...ntBox.zip?dl=0
I use the following BCs:
alphat
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0;
boundaryField
    adiabatic
        type alphatJayatillekeWallFunction;
        Prt 0.90;
        value $internalField;
    bottomWall
        Prt 0.90;
    bottomOpeningLeft
        type calculated;
    bottomOpeningRight
        type calculated;
    topWall
        Prt 0.90;
    topOpeningLeft
        type calculated;
    topOpeningRight
        type calculated;
k
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.1;
boundaryField
    adiabatic
        type kqRWallFunction;
    bottomWall
    bottomOpeningLeft
        type inletOutlet;
        inletValue $internalField;
    bottomOpeningRight
        type inletOutlet;
    topWall
    topOpeningLeft
        type inletOutlet;
    topOpeningRight
        type inletOutlet;
nut
internalField uniform 0.0;
boundaryField
    adiabatic
        type nutUWallFunction;
    bottomWall
    bottomOpeningLeft
        type calculated;
    bottomOpeningRight
        type calculated;
    topWall
    topOpeningLeft
        type calculated;
    topOpeningRight
        type calculated;
omega
dimensions [0 0 -1 0 0 0 0];
internalField uniform 1.1;
boundaryField
    adiabatic
        type omegaWallFunction;
    bottomWall
    bottomOpeningLeft
        type inletOutlet;
    bottomOpeningRight
        type inletOutlet;
    topWall
    topOpeningLeft
        type inletOutlet;
    topOpeningRight
        type inletOutlet;
p
internalField uniform 0.;
boundaryField
    adiabatic
        type calculated;
    bottomWall
        type calculated;
    bottomOpeningLeft
        type calculated;
    bottomOpeningRight
        type calculated;
    topWall
        type calculated;
    topOpeningLeft
        type calculated;
    topOpeningRight
        type calculated;
p_rgh
boundaryField
    adiabatic
        type fixedFluxPressure;
        rho rhok;
    bottomWall
        rho rhok;
    bottomOpeningLeft
        type prghPressure;
        p   $internalField;
        rho rhok;
    bottomOpeningRight
        type prghPressure;
        p   $internalField;
        rho rhok;
    topWall
        rho rhok;
    topOpeningLeft
        type prghPressure;
        p   $internalField;
        rho rhok;
    topOpeningRight
        type prghPressure;
        p   $internalField;
        rho rhok;
T
dimensions [0 0 0 1 0 0 0];
internalField uniform 303;
boundaryField
    adiabatic
        type zeroGradient;
    bottomWall
        type zeroGradient;
    bottomOpeningLeft
        type zeroGradient;
    bottomOpeningRight
        type zeroGradient;
    topWall
        // type fixedGradient;
        // gradient uniform 4166.0;
        type fixedValue;
        value uniform 353;
    topOpeningLeft
        type zeroGradient;
    topOpeningRight
        type zeroGradient;
U
dimensions [0 1 -1 0 0 0 0];
internalField uniform ( 0. 0. 0. );
boundaryField
    adiabatic
        type noSlip;
    bottomWall
        type noSlip;
    bottomOpeningLeft
        type pressureInletOutletVelocity;
    bottomOpeningRight
    topWall
        type noSlip;
    topOpeningLeft
    topOpeningRight
transportProperties
transportModel Newtonian;
// Laminar viscosity
nu              1.89e-05;
// Thermal expansion coefficient
beta            3e-03;
// Reference temperature
TRef            303;
// Laminar Prandtl number
Pr              0.70;
// Turbulent Prandtl number
Prt             0.90;
fvSchemes
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div(phi,T)      Gauss upwind;
    turbulence      Gauss upwind;
    div(phi,k)      $turbulence;
    div(phi,omega) $turbulence;
    div(phi,R)      $turbulence;
    div(R)          Gauss linear;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         uncorrected;
wallDist
    method          meshWave;
SadBoySquad is offline   Reply With Quote
Old   August 6, 2022, 09:20
So, no ideas on what I am doing wrong?
Old   August 6, 2022, 10:12
Kumaresh
Kummi is on a distinguished road
Send a message via Yahoo to Kummi
Let's arrange for a meeting and discuss about it
Kummi is offline   Reply With Quote
Old   August 6, 2022, 11:35
Hello!
Are you sure you replied to the correct thread?
Kummi likes this.
Old   August 11, 2022, 05:26
Ok, I'm up for a meeting.
How are we going to do it?
Old   August 25, 2022, 11:31
Joachim Herb
jherb is on a distinguished road
Two suggestions:
- Set up a simialar case (same heights) with only one inlet and one outlet and see, if the problem is still there.
- Use fixedValue boundary conditions for the inlet(s)/outlet(s) for p_rgh. If I understand the prghPressure boundary conditions (https://www.openfoam.com/documentati...8H_source.html) correctly, you apply the same (real) pressure to the in- and outlets. But shouldn't p for the (highter) outlets be lower than for the (lower) inlets. By setting p_rgh to the same fixed value at the in- and outlets, you effectively should have a lower pressure at the higher outlets.
jherb is offline   Reply With Quote
Flow around an object which contains openings BabakArash Main CFD Forum 2 December 15, 2017 11:19
3 Stage axial compressor CFX Setup knixxor CFX 9 November 29, 2016 14:38
2D Glass Melt Simulation Setup marmz FLUENT 5 October 9, 2016 16:25
[ICEM] surface/curve mesh setup Studi ANSYS Meshing & Geometry 15 November 12, 2014 01:32
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
