I can't add turbulence model in multiPhaseEulerFoam |
April 12, 2022, 10:07 |
saeed sangchooly
Rep Power: 4 |
hi everyone
I'm trying to simulate a 3phase case with multiphaseEulerFoam solver. water, oil and air. with interfaceCompression for (air and water) and (air and oil). I can't add komegaSSTSato or any other turbulence model. in the first time step when it comes to solving transport equation for turbulence parameters (k,omega,..) the solver give me the Floating point exception error. I've tried using the results of a laminar case as initial condition for my turbulence case. I've tried many hexahedral meshes with really good quality up to 1m cells. I've tried many turbulence parameters estimations for initial and boundary condition for each phase. I really dont know what I'm missing here. it would be great if anyone can give me a clue . |
April 14, 2022, 20:34 |
#2 | |
saeed sangchooly
Rep Power: 4 |
April 20, 2022, 04:18 |
Rep Power: 8 |
can you tell which OF version you use?
can you use the banana-trick and show us the ouput? should look like this: --> FOAM FATAL ERROR: Unknown RASModel type banana Valid RASModel types: 2 ( kEpsilon kOmegaSST ) here you can see that multiphaseEulerFoam for my custom solver can only use 2 tubulence models. is komegaSSTSato a valid option in your case? |
April 24, 2022, 12:51 |
#4 | |
saeed sangchooly
Rep Power: 4 |
currently Im trying to use komegaSSTSato and this is the output of banana-trick: --> FOAM FATAL ERROR: [4] Unknown RASModel type kOmegaSSSato Valid RASModel types: 8 ( LaheyKEpsilon continuousGasKEpsilon kEpsilon kOmegaSST kOmegaSSTSato kineticTheory mixtureKEpsilon phasePressure ) |
April 25, 2022, 07:27 |
Rep Power: 8 |
ok, so kOmegaSSTSato is a valid option.
the floating point exception error ist most likely the result of a division by zero. when you initialize your turbulence values such as k and omega, do not set the values in the domain to zero. for an initial test run do not use wall functions for turbulence properties, use zero gradient instead and see if it is running. try these suggestions out and let me know if it works. |
May 15, 2022, 13:58 |
saeed sangchooly
Rep Power: 4 |
Im sorry it took me a while to answer.
I've tried it (zerogradient) , it didn't work. I've no idea... |
May 9, 2024, 13:38 |
Raphael Santos
Rep Power: 13 |
check if your setup has no "0" value for omega or k for each phase. At least, use something as "value uniform 1e-14;", but avoid "0". |
komegasstsato, multiphaseeulerfaom, openfoam, openfoam 1806, turbulence model |
gamma-ReTheta turbulence model for predicting transitional flows | FelixL | OpenFOAM Programming & Development | 123 | August 30, 2022 11:50 |
NEW turbulence TRANSITIONAL model | giammy92 | OpenFOAM | 3 | June 30, 2016 09:47 |
Turbulence Model and limitation to Reynolds number | qascapri | FLUENT | 0 | January 24, 2011 10:48 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Why Turbulence models are not universal. | Senthil | Main CFD Forum | 4 | July 5, 2000 04:34 |
