triangular pipe flow problem
Like Tree1Likes
  • 1 Post By al.csc
Old   January 9, 2022, 04:53
Default triangular pipe flow problem
XIN QIU
Quest.Qiu is on a distinguished road
Dear All,
I am trying to simulate a two-phase pipe flow question with interFoam solver. I found the solution is quite good with circular section pipe, but is not good with triangular pipe. I guess it is the mesh quality problem and tried different way of meshing. But all of them are bad. Does anyone know how to fix it? Any advice would be useful.
http://m.qpic.cn/psc?/V11Cdl5T0ExPCp...A!&rf=viewer_4
Quest.Qiu is offline   Reply With Quote
Old   January 14, 2022, 12:33
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Pictures are not available.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   January 15, 2022, 22:16
XIN QIU
Thanks for your answer. I have upgraded my picture.
Old   January 17, 2022, 08:48
Tobi's Avatar
Tobias Holzmann
In that case, take care of your numerical schemes. Check your mesh using
checkMesh
and apply the appropriate numerical schemes onto your case.
Keep foaming,
Tobias Holzmann
Old   February 1, 2022, 02:49
Al Csc
al.csc is on a distinguished road
Originally Posted by Quest.Qiu View Post
Dear All,
Mesh looks good but the numerical recipe probably needs to be adjusted, as Tobi mentioned.
Have you tried pointCellsLeastSquares as gradSchemes? Increase nCorrectors to 3 and/or nNonOrthogonalCorrectors to 1.
With the latest ESI version, I personally would use isoAdvector, plicRDF reconstructionScheme and the hexahedra based mesh you posted. But be aware of max(Alpha)Co <1 limitation.
Cheers
Tobi likes this.
al.csc is offline   Reply With Quote
mesh, pipe flow
3D Swirl flow in the pipe: convergence problem Sachin U. Nimbalkar FLUENT 5 December 22, 2016 02:34
problem with solving pipe flow in rotating reference frame rpienika Main CFD Forum 0 March 11, 2016 16:25
Two-phase flow in a circular horizontal pipe DmitryS Fluent Multiphase 0 May 17, 2014 17:22
problem on Laminar flow in a pipe Goutam OpenFOAM Running, Solving & CFD 4 March 20, 2012 11:13
air flow in pipe with heat problem keng Main CFD Forum 1 March 5, 2010 11:40
