November 17, 2021, 11:47 |
Illegal cell label -1, fluent3DMeshToFoam
Ben Gherardi
Rep Power: 10 |
Hello foamers,
I am trying to convert a mesh from fluent to openfoam, and I am blocked at the following error: Code:
Create time Dimension of grid: 3 Number of points: 6926048 Number of faces: 12597122 Number of cells: 3106054 PointGroup: 11562 start: 0 end: 42135. Reading points...done. PointGroup: 18 start: 42136 end: 42365. Reading points...done. PointGroup: 29 start: 42366 end: 42387. Reading points...done. PointGroup: 31 start: 42388 end: 42409. Reading points...done. PointGroup: 33 start: 42410 end: 42429. Reading points...done. PointGroup: 35 start: 42430 end: 42451. Reading points...done. PointGroup: 37 start: 42452 end: 42471. Reading points...done. PointGroup: 39 start: 42472 end: 42493. Reading points...done. PointGroup: 55 start: 42494 end: 43408. Reading points...done. PointGroup: 75 start: 43409 end: 44884. Reading points...done. PointGroup: 95 start: 44885 end: 45538. Reading points...done. PointGroup: 103 start: 45539 end: 45687. Reading points...done. PointGroup: 11624 start: 45688 end: 310456. Reading points...done. PointGroup: 11633 start: 881799 end: 6926047. Reading points...done. PointGroup: 11640 start: 310457 end: 319728. Reading points...done. PointGroup: 11897 start: 319729 end: 881798. Reading points...done. FaceGroup: 11597 start: 0 end: 275917. Reading mixed faces...done. FaceGroup: 11572 start: 275918 end: 277552. Reading mixed faces...done. FaceGroup: 11571 start: 277553 end: 279196. Reading mixed faces...done. FaceGroup: 11570 start: 279197 end: 280584. Reading mixed faces...done. FaceGroup: 11569 start: 280585 end: 282229. Reading mixed faces...done. FaceGroup: 11568 start: 282230 end: 283974. Reading mixed faces...done. FaceGroup: 11567 start: 283975 end: 285625. Reading mixed faces...done. FaceGroup: 11631 start: 376428 end: 12597121. Reading mixed faces...done. FaceGroup: 98 start: 285626 end: 286929. Reading uniform faces...done. FaceGroup: 78 start: 286930 end: 289877. Reading uniform faces...done. FaceGroup: 58 start: 289878 end: 291703. Reading uniform faces...done. FaceGroup: 27 start: 291704 end: 291771. Reading uniform faces...done. FaceGroup: 26 start: 291772 end: 291853. Reading uniform faces...done. FaceGroup: 25 start: 291854 end: 291921. Reading uniform faces...done. FaceGroup: 24 start: 291922 end: 291999. Reading uniform faces...done. FaceGroup: 23 start: 292000 end: 292081. Reading uniform faces...done. FaceGroup: 21 start: 292082 end: 292159. Reading uniform faces...done. FaceGroup: 2 start: 292160 end: 376427. Reading uniform faces...done. CellGroup: 11629 start: 0 end: 3106053 type: 1 --> FOAM Warning : Found unknown block of type: "71" on line 19523259 --> FOAM Warning : Found unknown block of type: "71" on line 19788032 --> FOAM Warning : Found unknown block of type: "71" on line 19789687 --> FOAM Warning : Found unknown block of type: "71" on line 19791436 --> FOAM Warning : Found unknown block of type: "71" on line 19793085 --> FOAM Warning : Found unknown block of type: "71" on line 19794477 --> FOAM Warning : Found unknown block of type: "71" on line 19796125 --> FOAM Warning : Found unknown block of type: "71" on line 19797764 Zone: 11629 name: fluid-region-1 type: fluid. Reading zone data...done. Zone: 2 name: origin-glider type: wall. Reading zone data...done. Zone: 21 name: origin-tunnel-zmax type: wall. Reading zone data...done. Zone: 23 name: origin-tunnel-zmin type: wall. Reading zone data...done. Zone: 24 name: origin-tunnel-ymax type: wall. Reading zone data...done. Zone: 25 name: origin-tunnel-xmin type: wall. Reading zone data...done. Zone: 26 name: origin-tunnel-ymin type: wall. Reading zone data...done. Zone: 27 name: origin-tunnel-xmax type: wall. Reading zone data...done. Zone: 58 name: fine type: wall. Reading zone data...done. Zone: 78 name: medium type: wall. Reading zone data...done. Zone: 98 name: coarse type: wall. Reading zone data...done. Zone: 11631 name: interior--fluid-region-1 type: interior. Reading zone data...done. Zone: 11567 name: tunnel-zmax type: velocity-inlet. Reading zone data...done. Zone: 11568 name: tunnel-xmax type: velocity-inlet. Reading zone data...done. Zone: 11569 name: tunnel-ymin type: velocity-inlet. Reading zone data...done. Zone: 11570 name: tunnel-xmin type: pressure-outlet. Reading zone data...done. Zone: 11571 name: tunnel-ymax type: velocity-inlet. Reading zone data...done. Zone: 11572 name: tunnel-zmin type: velocity-inlet. Reading zone data...done. Zone: 11597 name: glider type: wall. Reading zone data...done. --> FOAM Warning : Found unknown block of type: "73" on line 20063727 FINISHED LEXING Creating patch 0 for zone: 11597 name: glider type: wall Creating patch 1 for zone: 11572 name: tunnel-zmin type: velocity-inlet Creating patch 2 for zone: 11571 name: tunnel-ymax type: velocity-inlet Creating patch 3 for zone: 11570 name: tunnel-xmin type: pressure-outlet Creating patch 4 for zone: 11569 name: tunnel-ymin type: velocity-inlet Creating patch 5 for zone: 11568 name: tunnel-xmax type: velocity-inlet Creating patch 6 for zone: 11567 name: tunnel-zmax type: velocity-inlet Creating patch 7 for zone: 98 name: coarse type: wall Creating patch 8 for zone: 78 name: medium type: wall Creating patch 9 for zone: 58 name: fine type: wall Creating patch 10 for zone: 27 name: origin-tunnel-xmax type: wall Creating patch 11 for zone: 26 name: origin-tunnel-ymin type: wall Creating patch 12 for zone: 25 name: origin-tunnel-xmin type: wall Creating patch 13 for zone: 24 name: origin-tunnel-ymax type: wall Creating patch 14 for zone: 23 name: origin-tunnel-zmin type: wall Creating patch 15 for zone: 21 name: origin-tunnel-zmax type: wall Creating patch 16 for zone: 2 name: origin-glider type: wall Creating cellZone 0 name: fluid-region-1 type: fluid Creating faceZone 0 name: interior--fluid-region-1 type: interior faceZone from Fluent indices: 376428 to: 12597121 type: interior patch 0 from Fluent indices: 0 to: 275917 type: wall patch 1 from Fluent indices: 275918 to: 277552 type: velocity-inlet patch 2 from Fluent indices: 277553 to: 279196 type: velocity-inlet patch 3 from Fluent indices: 279197 to: 280584 type: pressure-outlet patch 4 from Fluent indices: 280585 to: 282229 type: velocity-inlet patch 5 from Fluent indices: 282230 to: 283974 type: velocity-inlet patch 6 from Fluent indices: 283975 to: 285625 type: velocity-inlet patch 7 from Fluent indices: 285626 to: 286929 type: wall patch 8 from Fluent indices: 286930 to: 289877 type: wall patch 9 from Fluent indices: 289878 to: 291703 type: wall patch 10 from Fluent indices: 291704 to: 291771 type: wall patch 11 from Fluent indices: 291772 to: 291853 type: wall patch 12 from Fluent indices: 291854 to: 291921 type: wall patch 13 from Fluent indices: 291922 to: 291999 type: wall patch 14 from Fluent indices: 292000 to: 292081 type: wall patch 15 from Fluent indices: 292082 to: 292159 type: wall patch 16 from Fluent indices: 292160 to: 376427 type: wall --> FOAM FATAL ERROR: Illegal cell label -1 in neighbour addressing for face 12506320 From function void Foam::polyMesh::initMesh() in file meshes/polyMesh/polyMeshInitMesh.C at line 64. FOAM exiting However 1) is quite old and using Icem instead of fluent meshing, and I tried to save as an ascii .cas as suggested in 2) but the error remains. Would anyone have an idea on how to solve this? EDIT: Looking at the source code of polyMeshInitMesh.C it seems there is an issue with the cell owning face 12506320, but I don't understand it nor how to fix it. Code:
#include "polyMesh.H" // * * * * * * * * * * * * * Private Member Functions * * * * * * * * * * * // void Foam::polyMesh::initMesh() { DebugInFunction << "initialising primitiveMesh" << endl; // For backward compatibility check if the neighbour array is the same // length as the owner and shrink to remove the -1s padding if (neighbour_.size() == owner_.size()) { label nInternalFaces = 0; forAll(neighbour_, facei) { if (neighbour_[facei] == -1) { break; } else { nInternalFaces++; } } neighbour_.setSize(nInternalFaces); } label nCells = -1; forAll(owner_, facei) { if (owner_[facei] < 0) { FatalErrorInFunction << "Illegal cell label " << owner_[facei] << " in neighbour addressing for face " << facei << exit(FatalError); } nCells = max(nCells, owner_[facei]); }
Enjoy the flow Last edited by BenGher; November 18, 2021 at 11:46. Reason: Supplementary information |
December 8, 2021, 08:13 |
Ben Gherardi
Rep Power: 10 |
Update
I tried to use the simpler version "FluentMeshToFoam", but end up having the same problem. Currently trying to set up a really simple case (3D sphere) to see if I can reproduce the error, or if it comes from the .stl. In the meantime if anyone has any tips, or direction for me to look into, I would be glad. PS: I am aware that the post could be better suited to the "meshing" section of this forum, but I can't delete or move it, and don't want to double post.
Enjoy the flow |
June 15, 2022, 07:00 |
Rep Power: 8 |
are you sure that you did export a volume mesh from ansys?
it looks like you did export a surface mesh. |
June 22, 2022, 09:29 |
#4 | |
Ben Gherardi
Rep Power: 10 |
I used File > Write > Mesh --> Files of type: Legacy Compressed Mesh Files (*.msh.gz), "write binary files" unticked, so I think so. I "gzip -d meshfile.msh.gz" in order to get the meshfile.msh...could there be an issue in the decompressing step? I just tried with another mesh, to be certain, and still have the exact same issue.
Enjoy the flow |
August 6, 2022, 04:36 |
Rep Power: 5 |
Hi Ben,
I am facing the same error when I import mesh from ICEM to openfoam. Have you found the actual reason for this? |
August 8, 2022, 11:01 |
Ben Gherardi
Rep Power: 10 |
Unfortunately not, which led me to consider other options than Fluent meshing. I am not familiar with ICEM, but a guy with a similar problem as yours posted this , and it seems he forgot to import/export the volume mesh. Hope it helps, don't hesitate to share the answer if you find it
Enjoy the flow |
August 8, 2022, 15:45 |
Rep Power: 5 |
I actually shifted to the Mesh module of ANSYS from ICEM. I didn't get the error when I imported it to OpenFOAM. I came across the thread you mentioned, I think it is one of the reasons to get this error. In the process, I discovered that you could do a check mesh in the ICEM or probably in Mesh (ANSYS module) too. I used to have some penetrating cells in ICEM, and if I import the same mesh in OpenFOAM, I get the error. Again, I am not sure the exact reason, but there are probably multiple factors. |
October 10, 2023, 01:02 |
Weisheng
Rep Power: 7 |
Not sure if you solved this. I was also caught with some of the errors while attempting to use a fluent mesh with "internal" type face zones that enclose a cell zone intended as a porous zone. The most important things I found:
- use Prepare for Solve in Fluent Meshing to remove the unnecessary parts of the mesh - export as .msh while unchecking Binary - run fluent3DMeshToFoam (remember to scale it if your Fluent mesh is in mm and OF parameters are in SI). The utility should ignore the "internal" zones. Check your constant/PolyMesh files to be sure. |
conversion error, fluent3dmeshtofoam, mesh error, openfoam |
[snappyHexMesh] Error when setting locationsInMesh | elonesampaio | OpenFOAM Meshing & Mesh Conversion | 1 | April 3, 2021 18:44 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 05:17 |
[ANSYS Meshing] Is it possible to generate mesh in different cell zones in Ansys meshing? | aja1345 | ANSYS Meshing & Geometry | 0 | October 3, 2018 15:22 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 15:06 |
