Implementing a new turbulence model
Like Tree3Likes
  • 1 Post By s1291
  • 1 Post By s1291
  • 1 Post By s1291
Old   November 9, 2021, 20:06
Exclamation Implementing a new turbulence model
Sakun
Sakun is on a distinguished road
I am desperately need to know how to create my own turbulence model using existing models. i followed many different types of tutorials but file structure, names, and paths are totally changed in both OpenFOAM v9 and v8.
Any sort of a guidance appreciated ,
Sakun is offline   Reply With Quote
Old   November 10, 2021, 04:04
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Could try with OpenFOAM-v2106, it retains the familiar structure of turbulence models.
olesen is offline   Reply With Quote
Old   November 10, 2021, 11:43
Sakun
really appreciate your quick reply,
managed to install OpenFOAMv2106 but encountered with an error in third-party package
also i would like to introduce myself to you and ask some questions regarding OpenFOAMv2106. via email, LinkedIn or private message if you don't mind.
thank you,
best regards,
Old   November 10, 2021, 11:47
s1291's Avatar
s1291 is on a distinguished road
thank you,
best regards,
What distribution of Linux you're using?
There are pre-compiled versions of OpenFOAM that you can install directly using your package manager without the need to compile it from sources.
More information can be found on this page:
https://develop.openfoam.com/Develop...is/precompiled
s1291 is offline   Reply With Quote
Old   November 10, 2021, 11:54
Sakun
thank you for your reply,
i am using Ubuntu 20.04 LTS version in virtual machine.
please can you tell me how and where can i get this, i am desperately trying to fix this and make my own turbulence model
Old   November 10, 2021, 12:02
s1291's Avatar
The instructions on how to install OpenFOAM for multiple distributions are provided in the link above. If you read carefully you will find the instructions relevant to Ubuntu:
https://develop.openfoam.com/Develop.../debian#ubuntu
Sakun likes this.
Old   November 10, 2021, 12:11
Sakun
ohhh i see, i will definitely try this,
this may sounds like stupid, but in this method, does this included with the paraview ?
Old   November 10, 2021, 12:27
s1291's Avatar
You can install paraview as follows:
sudo apt update
sudo apt install paraview
On Ubuntu 20.04, that will install Paraview 5.7 (of course you can download the latest version of Paraview from their website and add it to PATH). If you want to use the command paraFoam, then you need to create an alias and add it to your ~/.bashrc file:
alias paraFoam='touch case.foam; paraview case.foam'
restart the terminal or simply source the bashrc file:
source ~/.bashrc
To visualize your case, type:
paraFoam
Old   November 10, 2021, 18:31
Sakun
i got stuck from the step 3 just as shown in the attachment.
Old   November 10, 2021, 20:26
s1291's Avatar
That's not a command you supposed to run. It is an entry that will be added automatically if you run the previous commands.
So you need to run:
sudo apt install openfoam2106-default
Sakun likes this.
Old   November 10, 2021, 20:37
s1291's Avatar
Just out of curiosity because you've mentioned that you're running a virtual machine, what is the host OS? is it Windows 10?
If the answer is yes, you don't need a virtual machine to run Linux. Use Windows Subsystem for Linux (WSL). To view the GUI apps you need to install an X server such as VcXsrv.
With Windows 11, you can use WSLg to run Linux GUI apps out of the box.
Sakun likes this.
Old   November 11, 2021, 06:32
Sakun
sudo apt update
source ~/.bashrc
paraFoam
i get this enormous when launch paraview, as shown in the attachment
(yes my host is windows 10, i am using virtual machine cause i used to it pretty much. in the windows version, code system and flies are different right )
File Type: jpg Screenshot from 2021-11-11 10-12-23.jpg (79.5 KB, 6 views)
Old   November 11, 2021, 07:59
s1291's Avatar
I am afraid that will not work under VirtualBox (or at least it is hard to get it up and running). In fact, to get a "definitive" answer about this, your best option is to ask your question on Paraview support website:
https://discourse.paraview.org/c/paraview-support/7
Another solution is to use WSL as suggested above. You can find the detailed instructions on Microsoft website, or just search on Youtube-- I am sure you will get some step-by-step videos.
If you are able to enable WSL on your system and install a Linux distribution such as Ubuntu 20.04 you don't have to worry about your files being edited on Windows or Linux.
Moreover, you don't need to install a Linux version of Paraview anymore. Simply install a Windows version of Paraview from their website.
Old   November 11, 2021, 10:42
Sakun
I thought that is because of my laptop drivers cause,it is 7 years old. hope university computers dont ask for admin rights to install any of above software.
Old   November 11, 2021, 11:02
s1291's Avatar
To enable WSL, you must have administrator rights to do so.
Old   November 11, 2021, 14:56
Sakun
jezzzzz....
I will give it try using my laptop, by any chance are you familiar with implementing turbulence models?
in future i have to run simulations using DES,DDES, and IDDES. so i am trying some tutorials at the moment but no luck at the moment. if i am succeeded i can even acknowledge in what ever the papers i produce in future.
also i am keep looking articles and sources to get to know how to make SA-DES in to case, i really appreciate if you can give me some hints or guidance regarding that ?
implementing, openfoam, paraview
Problem with creating R file for SSG turbulence model Khozaei4000 OpenFOAM Running, Solving & CFD 3 April 26, 2022 17:02
Only two turbulence options available in CFX Pre Jack001 CFX 5 March 30, 2016 03:47
Implementing v2f turbulence model in 2.1.x - GName not declared error Thangam OpenFOAM Running, Solving & CFD 3 January 13, 2014 02:49
What model of turbulence choose to study an external aerodynamics case raffale OpenFOAM 0 August 23, 2012 06:45
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
