Meaning of time step and time in SimpleFoam.
Like Tree1Likes
  • 1 Post By Yann
Old   October 14, 2021, 10:01
Default Meaning of time step and time in SimpleFoam.
Ashutosh
night-hawk is on a distinguished road
Hi Everyone,
I am doing a simulation with MRF. Simulation must run up to 10s . Does setting end time = 10 in controlDict works? For PimpleFoam it is easy to understand this thing. But in simplefoam what does it mean?
night-hawk is offline   Reply With Quote
Old   October 14, 2021, 10:31
Yann
Yann will become famous soon enoughYann will become famous soon enough
Since simpleFoam is a steady solver there is no notion of time, but only a number of iteration. So basically timeStep is 1 and endTime is the maximum number of iterations you want to run. (lets say, 2000)
But you can set timeStep to 0.1 and endTime to 200, it will be exactly the same (it will run 2000 iterations)
Saying "Simulation must run up to 10s" does not really make sense with a steady solver.
Keep in mind OpenFOAM is coded to be very generic so controlDict is meant to deal with time and timesteps despite those names are not really relevant for the specific case of steady solvers.
I hope this helps,
Yann
night-hawk likes this.
Yann is offline   Reply With Quote
Old   October 14, 2021, 11:14
Ashutosh
Originally Posted by Yann View Post
I hope this helps,
Yann
What about simpleFoam with MRF? If I apply rotation using MRF with simpleFoam.
Old   October 14, 2021, 11:48
Yann
I am sorry but I am not sure to understand your question, using MRF or not does not make a difference for what is written in my previous post.
MRF is a steady state method to model rotating objects, there is no mesh or part motion. (You could not use a transient modeling technique in a steady solver framework anyway)
Yann
Old   October 14, 2021, 11:59
Ashutosh
Yann
Thanks for your reply, My confusion was if I do simulation with pimpleFoam + MRF and take it readings after it becomes steady and doing same simulation with simpleFoam + MRF will answer be different?
Convergence problem of OF WUYing OpenFOAM Running, Solving & CFD 2 September 20, 2021 11:09
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores puneet336 OpenFOAM Running, Solving & CFD 11 April 7, 2019 01:58
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
