October 4, 2021, 20:55 |
Converge Simple
Humberto
Rep Power: 5 |
I was doing an example that I found on the internet, square tube, and I noticed that my simulation did not converge with the precision that converged in the example. (the example used the same parameters as simpleFoam/pitzDaily)
I noticed the error was in fvSolution. And the bad precision of the convergence was because of the Simple algorithm, which had not put the: "consistent yes" and the residualControl. But my doubt is to know why this? why do i have to put the consistent and the residualControl so that it converges right? |
October 6, 2021, 08:27 |
Humberto
Rep Power: 5 |
I found the solution. In general it was a pretty dumb question.
When using consistent I was enabling the SIMPLEC method and it has a convergence gain between 20% to 30% compared to normal SIMPLE, so the convergence in my solution was faster. |
Are simulations done in Converge 3.0 not possible to do in Converge 2.4? | EternalSeekerX | CONVERGE | 1 | March 29, 2021 08:10 |
Installed Converge on CentOS 7, converge solvers via command line work, gui doesn't? | EternalSeekerX | CONVERGE | 1 | December 2, 2020 11:15 |
A simple tube FSI case can't converge | stickjohnson | OpenFOAM | 1 | June 23, 2014 22:42 |
SIMPLE algorithm in 3D cylindrical coordinates | zouchu | Main CFD Forum | 1 | January 20, 2014 18:02 |
Normaly how long does it take for a simple LES to converge? | Basy | OpenFOAM | 1 | October 16, 2011 04:51 |
