Information about multiphaseEulerFoam wallBoiling tutorial |
Rep Power: 6 ![]() |
Hello Foamers,
I would like to use multiphaseEulerFoam to study the phase change in a water-vapor system. The tutorial wallBoiling (tutorials/multiphase/multiphaseEulerFoam/RAS/wallBoiling) seems to be the perfect point to start. I am especially curious because at the end there is a comparison with experiment, but the code does not give much information about the experimental data. Is there a paper explaining this comparison or explaining the experiment ? On another note, is there somewhere some resource to understand how to set up a multiphase flow with phase change in OpenFoam? Thank you for any information. |
anonymous
Rep Power: 0 ![]() |
I remember that the wall boiling tutorials in the openfoam is the freon experiment named DEBORA. You can get your information about the experiment from published papers.
multiphase flows, multiphaseeulerfoam, phase change, wall boiling |
Spalart-Allmaras turbulence model for turbulent flat plate tutorial | Bartholomew | OpenFOAM | 0 | February 6, 2021 18:24 |
fluxRequired OpenFoam Versions SimpleFoam Taylor Couette flow tutorial | mörli | OpenFOAM Running, Solving & CFD | 0 | April 9, 2019 11:50 |
help with 3D Bifurcating Artery tutorial - no wall shear seen | 9aul | FLUENT | 0 | January 15, 2018 18:20 |
[Tutorials] New Dakota - OpenFOAM Coupling Tutorial | Tobi | OpenFOAM Community Contributions | 0 | October 9, 2016 17:19 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
