Cyclic 'U' and Non-cyclic 'Scalar' on cyclic boundary
Like Tree2Likes
  • 1 Post By piu58
  • 1 Post By piu58
Old   July 29, 2021, 06:28
Question Cyclic 'U' and Non-cyclic 'Scalar' on cyclic boundary
Shengjie Lu
hhu_lulu is on a distinguished road
Dear FOAMers:
I am using OpenFOAM 7.0 to simulate the scalar transport in curved open channel, with interFoam and smagorinsky LES model.
In order to get the fully developed flow field, I impose cyclic BC for U and p_rgh at INLET and OUTLET. For the variable scalar, I impose Dirichlet BC at INLET and Neumann BC at OUTLET. It turns out not working. OpenFOAM requires the same cyclic BC for scalar. BTW, the scalar is released in the form of point source near the INLET.
How could I realize the above request? Any ideas are appreciated.
Thanks in advance!
Here I post my boundary file, U file and scalar file:
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
4
    INLET
        type            cyclic;
        inGroups        1(cyclic);
        nFaces          3600;
        startFace       10239600;
        matchTolerance  0.0001;
        transform       unknown;
        neighbourPatch  OUTLET;
    OUTLET
        type            cyclic;
        inGroups        1(cyclic);
        nFaces          3600;
        startFace       10243200;
        transform       unknown;
        neighbourPatch  INLET;
    WALLS
        type            wall;
        inGroups        1(wall);
        nFaces          163200;
        startFace       10246800;
    ATMOSPHERE
        type            patch;
        nFaces          86400;
        startFace       10410000;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    INLET
        type            cyclic;
    OUTLET
        type            cyclic;
    WALLS
        type            noSlip;
    ATMOSPHERE
        type            pressureInletOutletVelocity;
	value           uniform (0 0 0);
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      scalar1;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    INLET
        type            fixedValue;
	value           uniform 0;
    OUTLET
        type            zeroGradient;
    WALLS
        type            zeroGradient;
    ATMOSPHERE
        type            inletOutlet;
	inletValue      uniform 0;
	value           uniform 0;
hhu_lulu is offline   Reply With Quote
Old   July 29, 2021, 07:14
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
May be you can use the following appoach:
Calculate the flux (U and p) with your periodic b.c. but without the scaler. Uses scalaTransportFoam afterwards. You cannot get a transient result for the scalar, however.
hhu_lulu likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   July 29, 2021, 09:17
Shengjie Lu
Hi, Pilz, thanks for your reply!
Your idea sounds reasonable, I gonna adopt the advice and apply it in my simulation.
However, I am still wondering there are any simpler ways for cyclic cases.
Old   July 29, 2021, 13:07
piu58's Avatar
Uwe Pilz
It is always valuable de-coupling effects in a simulation. This way, scalarTransportFoam is easier not more complicated. And the results are more reliable in comparison ton al-in-all simulation.
Cyclic b.c. often arise problems and lead to nonphysical results. It may be you have to look for another approach anyway.
Uwe Pilz
Old   July 6, 2022, 00:06
Default Cyclic 'U' and Non-cyclic 'Scalar' on cyclic boundary
abdikerim kurbanaliev
kerim is on a distinguished road
Dear hhu lulu,
Were you able to solve your problem? I faced the same problem when I tried to simulate 2D periodic hills with passive scalar transport. Using scalarTransportFoam solver, as mentioned by piuy58, seems more perspective.
kerim is offline   Reply With Quote
Old   July 29, 2022, 13:23
Agustín Villa
agustinvo is on a distinguished road
Have you tried to add a heat sink using fvOptions/fvModels? In the paste several channel flows with similar scalar conditions were performed.
agustinvo is offline   Reply With Quote
Old   July 31, 2022, 01:51
Would you like to give a link to above mentioned channel flows?
Old   August 3, 2022, 01:23
Agustín Villa
I have been searching but I only found constant wall heat flux, I thought I saw something for fixed scalar value.
I have some ideas to deal with this problem
  • Compute the wall scalar flux so you get the amount of energy that comes in. Once you have it you can add a sink term in your scalar equation to decrease the scalar value in your domain. However the scalar profile is returned to the inlet.
  • There are some BC's called jumpCyclic and fixedJump that migth be interesting for you, however they apply an ofset isntead of reducing to a certain value your returned field. You can investigate these conditions and create a modified one for your purposes.
  • Going in the same direction, using mapped BC's for U you can move from cyclic to patch boundaries and you could use your actual BC's for the scalar.
I saw that your scalar BC's only have 0 values and zeroGradients. Unless you add a source of a BC with larger values you will see no changes.
Regards
Old   August 15, 2022, 12:40
Shengjie Lu
Dear hhu lulu,
Hi, Kerim:
Sorry for my slow reply.
I find a workaround with my issue. The periodic B.C. has still been used for the scalar in my case. To prevent the scalar from recycling, the scalarFixedValueConstraint has been used to set the value of scalar to 0 at the end of the computational domain. That is, the scalar is released from the source and it vanishes near the outlet, which would not influence the scalar transport in a single period.
I don't know whether this method matches your problem. Maybe you can elaborate on your cases. Thanks!
cyclic bc, interfoam, non-cyclic bc, openfoam, scalar transport
