paraview not importing initial fields
Like Tree1Likes
  • 1 Post By qutadah.r
Old   July 3, 2021, 04:36
Default paraview not importing initial fields
qutadah
qutadah.r is on a distinguished road
hi everyone, i am importing my meshed case into paraview manually with all initial fields set at t=0, the problem is the mesh is imported but the initial fields are not, what seems to be the problem? it is doing that for all cases... it will only show the fields in paraview when i run the solver...
please advise.
Note: I am importing manually because I seem to have a problem with my X server and there isnt really a way I have tried to fix it and it still doesnt work, so any other suggestion than running paraview from the command line would be appreciated. Thanks!
Qutadah
qutadah.r is offline   Reply With Quote
Old   July 5, 2021, 04:46
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hi Qutadah,
When loading your case in ParaView, make sure to uncheck the "Skip Zero Time" option in order to load the initial fields. (see the attached screenshot)
Cheers,
Yann
Yann is offline   Reply With Quote
Old   July 5, 2021, 16:46
qutadah
thanks alot! that fixed the problem
Yann likes this.
fields, openfoam, paraview
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 03:42
chtMultiRegionSimpleFoam turbulent case Aditya Patil OpenFOAM Running, Solving & CFD 6 April 24, 2017 23:13
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
