VAWT Modeling - Issue between Stationary and Rotating regions |
June 24, 2021, 10:49 |
Joel S J
Rep Power: 13 |
Hello All,
I am running a VAWT case using pimpleFoam with moving mesh (AMI). The pre-processing (mesh, physics, BCs, solvers) is apparently correct and the solution is running well. However, the results are strange on the interface side. We can clearly see the velocity gradients between the stationary and rotating regions that are not physically accepted. When looking at the "plot over line" we can see the velocity discontinuity between the stationary and rotative frames. Please find attached some images to illustrate the issue. I have run a propeller case before using the same setup and the results were much better. Have you seen such kind of behavior before? Any idea how I can improve this? Thank you for your help. |
June 24, 2021, 13:25 |
Conformal mesh interface
Rahul Vadrabade
Rep Power: 8 |
Very well explained. Just wanted to know are the mesh regions conformal at interface? As, such it is not required but can result in good results. Also, do you have any results, research, other commercial software results to compare? If not then a good idea to check in other tools also. Thanks |
June 24, 2021, 15:43 |
#3 | |
Joel S J
Rep Power: 13 |
The mesh is non-conformal. It's not necessary to be conformal due to the rotating movement. I did some research and I've seen that is more usual to find this kind of case in 2D. It sounds like that the 3D model is more difficult to converge. Thanks |
Fluent Mixing: Stationary Body not Affected by Rotating Body? | chenhuyun | FLUENT | 1 | May 5, 2020 06:51 |
Opening frame type (rotating, stationary)? | urosgrivc | CFX | 0 | July 3, 2017 05:24 |
[ICEM] Issue to create conformal interface between stationary and rotating domain | rohit_patil1125 | ANSYS Meshing & Geometry | 9 | March 22, 2017 17:44 |
Rotating or stationary domain in pump/turbine cavity | Christian Høy | CFX | 3 | March 17, 2017 06:03 |
horizontal axis wind turbine- Issue in interface b/w stationary and rotating domain. | srijithbbk | CFX | 5 | February 22, 2016 04:20 |
