Dynamic code not compiling: codestream and #calc
Like Tree4Likes
  • 3 Post By HPE
  • 1 Post By olesen
Old   April 16, 2021, 12:13
Default Dynamic code not compiling: codestream and #calc
Geb1313 is on a distinguished road
Hi Foamers,
I am using OpenFoam-v2012 on WSL. When my cases have #calc or #codestream, dynamic code failed to compile giving the following error:
PHP Code:
 Create time
Could not load Creating block mesh from
"system/blockMeshDict"
Using #calc at line 34 in file
"/mnt/c/Users/gebrayha/OpenFoam/3Ddambreak/system/blockMeshDict"
Using #codeStream with "/mnt/c/Users/gebrayha/OpenFoam/3Ddambreak/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_62f249a623e510348c0dae9390b3984aa7beeadf.so"
/mnt/c/Users/gebrayha/OpenFoam/3Ddambreak/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_62f249a623e510348c0dae9390b3984aa7beeadf.socannot open shared object fileNo such file or directory
Creating
new library in "dynamicCode/_62f249a623e510348c0dae9390b3984aa7beeadf/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_62f249a623e510348c0dae9390b3984aa7beeadf.so"
Invoking wmake libso /mnt/c/Users/gebrayha/OpenFoam/3Ddambreak/dynamicCode/_62f249a623e510348c0dae9390b3984aa7beeadf
wmake libso
/opt/OpenFOAM/OpenFOAM-v2012/ThirdParty/platforms/linux64/gcc-6.3.0/bin/../libexec/gcc/x86_64-pc-linux-gnu/6.3.0/cc1error while loading shared librarieslibmpfr.so.4cannot open shared object fileNo such file or directory
    ln
: ./lnInclude
    ld
libNULL.so
Could not load
--> FOAM FATAL IO ERROR: (openfoam-2012)
Failed loading library "/mnt/c/Users/gebrayha/OpenFoam/3Ddambreak/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_62f249a623e510348c0dae9390b3984aa7beeadf.so"
Did you add all libraries to the 'libs' entry in system/controlDict?
file: /mnt/c/Users/gebrayha/OpenFoam/3Ddambreak/system/blockMeshDict at line 17 to 32.
    From
static void (* Foam::functionEntries::codeStream::getFunction(const Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
in file db/dictionary/functionEntries/codeStream/codeStream.C at line 305.
FOAM exiting
Any help please? Is this problem related to WSL or just I missed something?
Thank you
Gebray
Geb1313 is offline   Reply With Quote
Old   April 16, 2021, 17:59
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
To reproduce the error, I think we need a minimal reproducible example.
HPE is offline   Reply With Quote
Old   April 17, 2021, 13:56
Originally Posted by HPE View Post
Hi HPE,
For example let see this blockMeshdict :
*--------------------------------*- C++ -*----------------------------------*\
| \\ / O peration | Version: v2012 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
scale 1;
xmin 0.0;
xmax 4.0;
ymin -0.5;
ymax 0.5;
zmin 0;
zmax 0.5;
//xcells 20;
//ycells 20;
//zcells 1;
deltax 0.05; //0.05
deltay 0.05; //0.05
deltaz 0.05; //0.05
lx #calc "$xmax - $xmin";
ly #calc "$ymax - $ymin";
lz #calc "$zmax - ($zmin)";
xcells #calc "round($lx/$deltax)";
ycells #calc "round($ly/$deltay)";
zcells #calc "round($lz/$deltaz)";
vertices
//BLOCK1
($xmin $ymin $zmin) //0
($xmax $ymin $zmin) //1
($xmax $ymax $zmin) //2
($xmin $ymax $zmin) //3
($xmin $ymin $zmax) //4
($xmax $ymin $zmax) //5
($xmax $ymax $zmax) //6
($xmin $ymax $zmax) //7
blocks
hex (0 1 2 3 4 5 6 7) (xcells ycells zcells) simpleGrading (1 1 1)
edges
boundary
top
type wall;
faces
(4 5 6 7)
left
type wall;
faces
(0 4 7 3)
right
type wall;
faces
(1 2 6 5)
bottom
type wall;
faces
(0 3 2 1)
front
type wall;
faces
(0 1 5 4)
back
type wall;
faces
(2 3 7 6)
mergePatchPairs
Old   April 17, 2021, 16:30
HPE
HPE's Avatar
One issue is the missing dollar sign for the following variables:
Having said that I strongly recommend you to use #eval expression instead of #calc. With #eval, you will not need to deal with any compilation. Please search 'eval' among the tutorial cases and OpenFOAM release notes.
olesen, Geb1313 and Goatow like this.
Old   April 17, 2021, 19:18
Hi HPE,
Nice! Half of my problem is solved. I used #eval instead of #calc. However still the problem with #codestream persisted to continue. I was running a dambreak using interfoam. I want to introduce initial conditions for alpha.water using #codestream like this:
dimensions [0 0 0 0 0 0 0];
//internalField uniform 0;
internalField #codeStream
codeInclude
#include "fvCFD.H"
codeOptions
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude
//libs needed to visualize BC in paraview
codeLibs
-lmeshTools \
-lfiniteVolume
code
const IOdictionary& d = static_cast<const IOdictionary&>(dict);
const fvMesh& mesh = refCast<const fvMesh>(d.db());
scalarField alpha(mesh.nCells(), 0.);
forAll(alpha, i)
const scalar x = mesh.C()[i][0];
const scalar y = mesh.C()[i][1];
const scalar z = mesh.C()[i][2];
if (y <= 0.2)
alpha[i] = 1.;
writeEntry(os, "", alpha);
And the error message was similar which looks a compilation error like this:
Using #codeStream at line 20 in file "/mnt/c/Users/gebrayha/OpenFoam/3Ddambreak/0/alpha.water"
Using #codeStream with "/mnt/c/Users/gebrayha/OpenFoam/3Ddambreak/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_9a2905356e5313e2ff419c83e22111805dc3 aa4d.so"
Could not load "/mnt/c/Users/gebrayha/OpenFoam/3Ddambreak/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_9a2905356e5313e2ff419c83e22111805dc3 aa4d.so"
/mnt/c/Users/gebrayha/OpenFoam/3Ddambreak/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_9a2905356e5313e2ff419c83e22111805dc3 aa4d.so: cannot open shared object file: No such file or directory
Creating new library in "dynamicCode/_9a2905356e5313e2ff419c83e22111805dc3aa4d/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_9a2905356e5313e2ff419c83e22111805dc3 aa4d.so"
Invoking wmake libso /mnt/c/Users/gebrayha/OpenFoam/3Ddambreak/dynamicCode/_9a2905356e5313e2ff419c83e22111805dc3aa4d
/opt/OpenFOAM/OpenFOAM-v2012/ThirdParty/platforms/linux64/gcc-6.3.0/bin/../libexec/gcc/x86_64-pc-linux-gnu/6.3.0/cc1: error while loading shared libraries: libmpfr.so.4: cannot open shared object file: No such file or directory
ln: ./lnInclude
ld: libNULL.so
Failed loading library "/mnt/c/Users/gebrayha/OpenFoam/3Ddambreak/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_9a2905356e5313e2ff419c83e22111805dc3 aa4d.so"
file: /mnt/c/Users/gebrayha/OpenFoam/3Ddambreak/0/alpha.water at line 17.
From static void (* Foam::functionEntries::codeStream::getFunction(con st Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
FOAM exiting
Old   April 18, 2021, 05:21
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
You have Gcc63 as the compiler type, which makes it look like you have a separate gcc installation.
You should check the value of your LD_LIBRARY_PATH to verify that libmpfr (perhaps libgmp too) are accessible.
Since the compilation worked, but not the loading, use 'ldd -v' on the dynamically generated lib. Use Google or Stackoverflow or man if you aren't familiar with ldd.
Geb1313 likes this.
olesen is offline   Reply With Quote
Old   April 18, 2021, 08:46
Thank you for the reply olesen,
which gcc on the command line shows:
/opt/OpenFOAM/OpenFOAM-v2012/ThirdParty/platforms/linux64/gcc-6.3.0/bin/gcc
I don't think the problem is related to separate gcc installation(?)
To use the ldd -v [file], the file "_9a2905356e5313e2ff419c83e22111805dc3 aa4d.so" is not existing. When I look in to dynamicCode folder, there is no platforms sub-folder.
Looking in to config.sh/setting, I found:
_foamEtc -config compiler
# ThirdParty base for compilers
archDir="$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH"
case "$WM_COMPILER_TYPE-$WM_COMPILER" in
ThirdParty-Gcc*)
gccDir="$archDir/$gcc_version"
gmpDir="$archDir/${gmp_version:-gmp-system}"
mpfrDir="$archDir/${mpfr_version:-mpfr-system}"
mpcDir="$archDir/${mpc_version:-mpc-system}"
# Check that the compiler directory can be found
[ -d "$gccDir" ] || /bin/cat << GCC_NOT_FOUND 1>&2
Warning in $WM_PROJECT_DIR/etc/config.sh/settings:
Cannot find '$WM_COMPILER' compiler installation
$gccDir
Either install this compiler version, or use the system compiler by setting
WM_COMPILER_TYPE to 'system' in \$WM_PROJECT_DIR/etc/bashrc.
GCC_NOT_FOUND
_foamAddMan "$gccDir"/man
_foamAddPath "$gccDir"/bin
# Add ThirdParty compiler libraries to run-time environment
_foamAddLib "$gccDir/lib$WM_COMPILER_LIB_ARCH"
# Add gmp/mpfr/mpc libraries to run-time environment.
# Require that they exist, automatically find lib64/ or lib/.
_foamAddLibAuto "$gmpDir" && \
export GMP_ARCH_PATH="$gmpDir" # For non-system CGAL
_foamAddLibAuto "$mpfrDir" && \
export MPFR_ARCH_PATH="$mpfrDir" # For non-system CGAL
_foamAddLibAuto "$mpcDir"
if [ -n "$FOAM_VERBOSE" ] && [ -n "$PS1" ]
then
echo "Using ThirdParty compiler"
echo " ${gccDir##*/} (${gmpDir##*/} $${mpfrDir##*/} ${mpcDir##*/})"
fi
I am not sure whether this will help or not, but it is only this I could figure out about "mpfr" and "gmp".
Sorry my ignorance about linux system
Old   July 21, 2023, 11:17
Mukul Chandra
risktaker5 is on a distinguished road
have you find the solution of the compilation error you were facing. Same compilation error I am also facing. Please help in this regard.
risktaker5 is offline   Reply With Quote
Old   July 24, 2023, 04:34
CFDUser29 is on a distinguished road
I agree with Olesen, the problem stands in gcc.
I you work on a cluster, I recommend to look for the versions you have with <spack find gcc> and then use <spack load gcc...> with the latest version.
If you work on your laptop, find a way to install gcc, using gcc@12.2.0 solved my codeStream problem.
CFDUser29 is offline   Reply With Quote
calc, codestream, dynamiccode
"Invalid line number" when compiling at runtime satter_partier OpenFOAM Programming & Development 7 July 16, 2019 07:01
