FOAM FATAL ERROR: No surfaces specified/found for entry: cylinder.stl |
April 3, 2021, 12:17 |
unseen
I'm getting this error on running the surfaceFeatureExtract command.
--> FOAM FATAL ERROR: (openfoam-2012) No surfaces specified/found for entry: cylinder.stl From int main(int, char**) in file surfaceFeatureExtract.C at line 305. FOAM exiting |
April 24, 2021, 05:19 |
Erick D. Martinez
Rep Power: 6 |
Make sure you have your cylinder.stl file in your constant/triSurface directory. Also what is your surfaceFeaturesExtractDict?
July 20, 2021, 19:33 |
Samuel Reimer
Hi, were you able to figure out the issue? I'm getting the same error following a tutorial and can't figure it out. As per the first comment, the cylinder.stl is in the TriSurface Folder, etc.
Here's the tutorial if you're wondering, seems like a great tutorial for importing CAD models but I just got stuck at this part: https://youtu.be/oc4V79F78AQ Thanks |
July 21, 2021, 05:18 |
Yann
Rep Power: 28 |
Hi Samuel,
You need to give more information about what you are doing: which OpenFOAM version do you use, what is inside you surfaceFeatureExtractDict, where is located your stl file, etc... As for now, the only thing we can say is: the file in missing in the constant/triSurface directory, as stated in the error message. You will probably not get more help without giving more inputs about what you are doing. Since linux is case-sensitive, be careful about the names of you files and directories (for instance: "triSurface" and not "TriSurface") Cheers, Yann |
July 21, 2021, 14:31 |
Samuel Reimer
Hi Yann,
Apologies, I typed triSurface in wrong here (cases were right in the terminal). Figured out the issue though, if anyone else has this issue make sure the stl file being referenced is renamed "file.stl" rather than how it saves as "file.STL". |
September 4, 2023, 12:19 |
remi deprez
Hello!
Thanks erickmartinez! Put the (object).obj file in the constant/triSurface directory worked for me! Note that the triSurface directory didn't exist in the motorBike tuto (openFOAM 2306), and the youtube tuto I watched put the (object).obj in a "geometry" folder... |
November 10, 2023, 10:59 |
Siddhartha Mukharjee
I am currently using OpenFOAM-v2112. I have been trying to run motorBike tutorial. But as I run surfaceFeatureExtract. An error pops up --> FOAM FATAL ERROR: (openfoam-2112 patch=220610) No surfaces specified/found for entry: motorBike.obj From int main(int, char**) in file surfaceFeatureExtract.C at line 308. Have anyone faced this problem |
July 31, 2024, 11:35 |
BabuG
Rep Power: 2 |
I faced this problem few times. First time I was trying to launch the tutorial case. this was resoled by launching the bash file: bash ./Allrun.PRE.
Further check the file extension in terminal. The file should be "file.stl" |
error, surfacefeatureextract |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
Derivative of velocity and mean velocity | hiuluom | OpenFOAM Post-Processing | 1 | May 30, 2015 00:42 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
[Gmsh] GmshToFoam FOAM FATAL ERROR faces deallocated | Tobias Prousa (Prousa) | OpenFOAM Meshing & Mesh Conversion | 14 | January 31, 2012 11:45 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
