Diego
Rep Power: 6 ![]() |
After what feels like years of googling, I feel I have given up and will move on to extrudeMesh which I know will be able to solve my problems.
I am creating a cylinder within a cylinder volume, and so I'm attempting to use blockMesh in order to create an axissymetric wedge of my problem. My issue is that though blockMesh works fine: Code:
Creating block edges No non-planar block faces defined Creating topology blocks Creating topology patches Creating block mesh topology Check topology Basic statistics Number of internal faces : 2 Number of boundary faces : 14 Number of defined boundary faces : 14 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list (topological search)... Deleting polyMesh directory "constant/polyMesh" Creating polyMesh from blockMesh Creating patches Creating cells Creating points with scale 0.001 Block 0 cell size : i : 0.000176056 .. 0.000176056 j : 0 .. 0 k : 0.000173913 .. 0.000173913 Block 1 cell size : i : 0.000172412 .. 0.000172412 j : 0.000436302 .. 0.000436302 k : 0.000173913 .. 0.000173913 Block 2 cell size : i : 0.000172412 .. 0.000172412 j : 0.000436302 .. 0.000436302 k : 0.000175066 .. 0.000175066 There are no merge patch pairs Detected cyclic patches; ordering boundary faces Writing polyMesh with 0 cellZones ---------------- Mesh Information ---------------- boundingBox: (0 -0.000305412 0) (0.0174973 0.000305412 0.07) nPoints: 27468 nCells: 13233 nFaces: 53432 nInternalFaces: 25966 ---------------- Patches ---------------- patch 0 (start: 25966 size: 29) name: air patch 1 (start: 25995 size: 13233) name: AMI1 patch 2 (start: 39228 size: 13233) name: AMI2 patch 3 (start: 52461 size: 500) name: beakerCylinder patch 4 (start: 52961 size: 448) name: toolCylinder patch 5 (start: 53409 size: 23) name: axis End Code:
Checking geometry... Overall domain bounding box (0 -0.000305412 0) (0.0174973 0.000305412 0.07) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-3.7654e-15 1.47052e-14 3.00031e-19) OK. Max cell openness = 1.70915e-16 OK. Max aspect ratio = 56.6022 OK. ***Zero or negative face area detected. Minimum area: 0 <<Writing 23 zero area faces to set zeroAreaFaces Min volume = 9.40625e-14. Max volume = 1.83433e-11. Total volume = 1.94124e-07. Cell volumes OK. Mesh non-orthogonality Max: 1.07995e-05 average: 0 Non-orthogonality check OK. Face pyramids OK. ***Max skewness = 1.17353e+146, 23 highly skew faces detected which may impair the quality of the results <<Writing 23 skew faces to set skewFaces Coupled point location match (average 9.02597e-10) OK. Failed 2 mesh checks. Contents of constant/polyMesh/boundary: Code:
axis { type empty; inGroups 1(empty); nFaces 23; startFace 53409; } ![]() I've gone through defining things as patches and wedges and seperating all my faces to putting them back together again, but I am well and truly stuck. Here's hoping you may be able to help me with my issues. blockMeshDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "cylinderRe" backgroundMesh { rOuter $rO; // inner radius of outer cylinder rTool $rT; // radius of the tool gap $d; // gap from tool to base of the beaker height $h; // cylinder height // Mesh n1x $n1x; n1z $n1z; n2x $n2x; n2z $n2z; n3x $n3x; n3z $n3z; } scale 1e-3; vertices ( (0 0 0) //0 ($rx1 $ty1 0) //1 ($rx2 $ty2 0) //2 (0 0 $:backgroundMesh.gap) //3 ($rx1 $ty1 $:backgroundMesh.gap) //4 ($rx2 $ty2 $:backgroundMesh.gap) //5 ($rx1 $ty1 $:backgroundMesh.height) //6 ($rx2 $ty2 $:backgroundMesh.height) //7 ($rx1 $ry1 0) //8 ($rx2 $ry2 0) //9 ($rx1 $ry1 $:backgroundMesh.gap) //10 ($rx2 $ry2 $:backgroundMesh.gap) //11 ($rx1 $ry1 $:backgroundMesh.height) //12 ($rx2 $ry2 $:backgroundMesh.height) //13 ); blocks ( // Zone 1 hex (0 1 8 0 3 4 10 3) ($:backgroundMesh.n1x 1 $:backgroundMesh.n1z) simpleGrading (1 1 1) // Zone 2 hex (1 2 9 8 4 5 11 10) ($:backgroundMesh.n2x 1 $:backgroundMesh.n2z) simpleGrading (1 1 1) // Zone 3 hex (4 5 11 10 6 7 13 12) ($:backgroundMesh.n3x 1 $:backgroundMesh.n3z) simpleGrading (1 1 1) ); edges ( ); boundary ( air { type patch; faces ( (6 7 13 12) ); } AMI1 { type cyclic; neighbourPatch AMI2; transform rotational; rotationAxis (0 0 1); rotationCentre (0 0 0); faces ( (1 2 5 4) (4 5 7 6) (0 1 4 3) ); } AMI2 { type cyclic; neighbourPatch AMI1; transform rotational; rotationAxis (0 0 1); rotationCentre (0 0 0); faces ( (8 10 11 9) (10 12 13 11) (0 3 10 8) ); } beakerCylinder { type wall; faces ( (2 9 11 5) (5 11 13 7) (2 1 8 9) (0 8 1 0) ); } toolCylinder { type wall; faces ( (4 6 12 10) (3 4 10 3) ); } axis { type empty; faces ( (0 3 3 0) ); } ); Code:
// Geometry (in mm) rO 17.5; // Beaker internal radius rT 12.5; // Tool radius d 4; // Tool height from the bottom of the beaker h 70; // Internal Cylinder height a #calc "constant::mathematical::pi/180"; // 9 degree slice rx1 #calc "$rT*cos($a)"; rx2 #calc "$rO*cos($a)"; ry1 #calc "$rT*sin($a)"; ry2 #calc "$rO*sin($a)"; ty1 #calc "-$ry1"; ty2 #calc "-$ry2"; // Mesh k #calc "100/$rO"; // Target cell density // Zone 1 n1x #calc "round($k*$rT)"; n1z #calc "round($k*$d)"; // Zone 2 n2x #calc "round($k*($rO - $rT))"; n2z #calc "round($k*$d)"; // Zone 3 n3x #calc "round($k*($rO - $rT))"; n3z #calc "round($k*($h - $d))"; // Azimuth y1 #calc "round($k*(2*$rT - $rO)*sin($a))"; y2 #calc "round($k*(0.5*$rT)*sin($a))"; // Operations omega_i #calc "42000*(2*constant::mathematical::pi/60)"; // Speed in rad/s v #calc "$omega_i*$rT*1e-3"; // linear velocity at the Tool |
Diego
This one weird trick solved all my problems:
mergeType points; |
Desh
Rep Power: 5 ![]() |
Thanks Diego, It was exactly my problem too, ''mergeType points;'' solves it. Thank you for saving me a lot of time.
Cheers, Dasith |
Rakesh Majumder
Rep Power: 0 ![]() |
blockmesh, blockmesh cylinder, openfoam 1806 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
