Equation in Burns.C of Turbulent dispersion model of Burns et al. |
October 22, 2020, 22:05 |
Chaoran Guan
Rep Power: 7 |
Hello, Foamers. I was using the reactingTwoPhaseEulerFoam of OF6.0 Version.
A turbulent dispersion model called Burns is used which located in applications/solvers/multiphase/reactingEulerFoam/interfacialModels/turbulentDispersionModels/Burns. And the reference is Burns, A. D., Frank, T., Hamill, I., & Shi, J. M. (2004, May).The Favre averaged drag model for turbulent dispersion in Eulerian multi-phase flows.In 5th international conference on multiphase flow, ICMF (Vol. 4, pp. 1-17). https://www.researchgate.net/publica...ti-Phase_Flows The equation used in Burns.C from the reference is And the correspponding source code in Burns.C from OF version 6.0 is Code:
0.75 *drag.CdRe() *pair_.continuous().nu() *continuousTurbulence().nut() /( sigma_ *sqr(pair_.dispersed().d()) ) *pair_.continuous().rho() *pair_.dispersed() *( 1.0/max(pair_.dispersed(), residualAlpha_) + 1.0/max(pair_.continuous(), residualAlpha_) ); The two equations seem not to be the same. The interphase velocity term is missed in the source code and there is an additional term in it. Is there any relationship between these two terms? |
November 24, 2020, 04:43 |
Rep Power: 8 |
drag.CdRe() in the code means C_d x Re (Reynolds number),
it cancels out the additional terms (kin. viscosity / bubble diameter) and leaves your missing term (velocity difference). so in the end it is implemented correctly although not in a way that makes sense at first sight. |
multiphase flows, multiphase modelling |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
How to use the turbulent dispersion in FLUENT? | marialhm | FLUENT | 2 | October 31, 2017 21:55 |
Confusion on the FAD (Burns) turb-dispersion model | spy_hzdr | Main CFD Forum | 0 | September 29, 2017 05:27 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
A new turbulent model without empirical coefficients | s9a9m92001 | OpenFOAM Programming & Development | 6 | October 10, 2013 00:11 |
