compiled errors while using DimensionedField<Type, GeoMesh>
Like Tree1Likes
  • 1 Post By Chaoran
Old   October 3, 2020, 03:46
Exclamation compiled errors while using DimensionedField<Type, GeoMesh>
Chaoran Guan
Chaoran is on a distinguished road
I encountered a compiled error while using Dimensioned<tensor, volMesh>. Here is what I wrote in the createFields.H of the icoFoam:
volTensorField Ut = fvc::grad(U);
DimensionedField<tensor, volMesh> Ud = Ut.internalField();
Info << Ud << endl;
Info << Ud.T() << endl;
And the compiled error was:
error: no matching function for call to ‘T(const Foam::Field<Foam::Tensor<double> >&, const Foam::Field<Foam::Tensor<double> >&)’ Foam::T(result(), *this);
Then I found the Foam::T() functions in the FieldFunctions.H is declared as
template<class Type> void T(Field<Type>& res, const UList<Type>& f);
However, the member function T() of the class dimensionedField<Type, GeoMesh> is defined as
 template<class Type, class GeoMesh> tmp<DimensionedField<Type, GeoMesh>> DimensionedField<Type, GeoMesh>::T() const
    tmp<DimensionedField<Type, GeoMesh>> result
        DimensionedField<Type, GeoMesh>::New
            name() + ".T()",
            mesh_,
            dimensions_
    return result;
where the operator() of the tmp<T> return a const reference of T rather than a non-const reference which is required by Foam::T() global function.
So, I modify the above code:
into:
Foam::T(result.ref(), *this);
After this modification, the compilation can be done successfully.
And I was using openFOAM 8 version. Is this a bug that has not been noticed in OpenFOAM yet?
Chaoran is offline   Reply With Quote
Old   October 4, 2020, 14:29
Hrvoje Jasak
This is a bug - missed in script changes. Can you report it please in the bug tracker?
Hrv
Hrvoje Jasak
Old   October 4, 2020, 22:33
Smile
Chaoran Guan
Hrv
I've reported the issue. https://bugs.openfoam.org/view.php?id=3564
Tobi likes this.
Old   October 14, 2020, 11:48
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by Chaoran View Post
https://develop.openfoam.com/Develop.../-/issues/1868
olesen is offline   Reply With Quote
bugs, dimensionedfield, fieldfunctons
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 10:10
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
LES, Courant Number, Crash, Sudden Alhasan OpenFOAM Running, Solving & CFD 5 November 22, 2019 03:05
decompose dependent solution arionfard OpenFOAM 3 December 10, 2018 10:36
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
