Beginner error: Entry 'freestreamValue' not found in dictionary |
July 21, 2020, 10:57 |
Rep Power: 6 |
SOLVED: freesteamPressure conditions are now defined as such: farfield { type freestreamPressure; freestreamValue $internalField; } I'm trying to run the below 2D wind turbine case, it was made in 2014 so I'm updating it for OF 2006. I've corrected quite a few errors due to version changes but I'm stuck on something that I think is easy to fix. Case https://github.com/traviscarrigan/OpenFOAM-2D-VAWT/tree/master/0 The full error: Code:
PIMPLE: Operating solver in PISO mode Reading field p --> FOAM FATAL IO ERROR: Entry 'freestreamValue' not found in dictionary "/home/lee/Documents/OpenFoam/01_tests/OpenFOAM-2D-VAWT-master/0/p.boundaryField.farfield" file: /home/lee/Documents/OpenFoam/01_tests/OpenFOAM-2D-VAWT-master/0/p.boundaryField.farfield at line 31 to 32. From const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, Foam::keyType::option) const in file db/dictionary/dictionary.C at line 413. FOAM exiting I tried to give a value to the farfield, uniform 1 ; but it didn't work either so I commented it (it's not how it's supposed to work, but I'm just trying stuff). Thanks Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { blades { type zeroGradient; } farfield { type freestreamPressure; //value uniform 1; } ext_interface { type cyclicAMI; value uniform 0; } int_interface { type cyclicAMI; value uniform 0; } sides { type empty; } } Last edited by DeadLee; July 21, 2020 at 14:41. |
Two phase flow in porous medium | Milaad | OpenFOAM | 7 | July 1, 2024 05:08 |
[RapidCFD] Discussion thread on how to install and use RapidCFD | newoscar | OpenFOAM Community Contributions | 88 | May 17, 2024 09:39 |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
[Other] Compiling hacFoam (Ubuntu 10.04)(OF2.0.0)(LAMMPS13Jul2010)) | Henrik_E | OpenFOAM Installation | 3 | September 29, 2016 16:16 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
