vortical strcutures
Like Tree2Likes
  • 2 Post By clapointe
Old   July 11, 2020, 12:41
Post vortical strcutures
Hiroya Matsuura
Hiroya Matsuura is on a distinguished road
I use OpenFoam studying for car analysis.
I don't understand how to indicate vorticity magnitude.
I want to see that vortical strctures with various scales are developed around the car.
Please let me know what should I do?
Hiroya Matsuura is offline   Reply With Quote
Old   July 15, 2020, 16:40
clapointe is on a distinguished road
There are a few function objects that should be useful. The first can be used to compute vorticity (https://github.com/OpenFOAM/OpenFOAM...ty/vorticity.H) as a volume field that you can then view, for example, using paraview. Another option to view vortical structures is by using the Q (https://github.com/OpenFOAM/OpenFOAM...ts/field/Q/Q.H) or Lambda2 (https://github.com/OpenFOAM/OpenFOAM...bda2/Lambda2.H) function objects. These will compute volume fields that can be used to identify coherent structures, where Q > 0 or Lamba2 < 0, respectively if I remember correctly. This appears to be a good reference : http://www.georgehaller.com/reprints/vortex.pdf.
All of the function objects I mentioned can be used as a post process step so you don't have to rerun a simulation.
Caelan
kcavatar and Chanikya_Valeti like this.
clapointe is offline   Reply With Quote
Old   August 1, 2020, 22:00
Default total pressure coefficient field
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
In aerodynamics simulations, the total pressure coefficients fields are also used to check the regions of vortical structures that cause drag increase.
Best regards,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
vorticity magnitude
Vortical Structure Capturing afrotimy OpenFOAM Programming & Development 1 March 9, 2015 14:37
Turbulence model for vortical flows Dan Chambers STAR-CCM+ 0 December 30, 2010 10:07
vortical Structure in CFX Post simulationCFX CFX 1 December 28, 2010 04:00
Helicity - Relative Helicity in CFX Post simulationCFX CFX 3 December 25, 2010 05:10
