best program to read and open big openfoam files |
July 10, 2020, 06:59 |
Rep Power: 7 |
i'm using ubuntu 17 and the base "text editor" is very slow while opening and then saving the input/output openfoam text file (like U, T etc), to open a file of 300 mb it needs 2-3 minutes. The hardware is good in fact I open instantly the same file using notepad++ on windows. My question is: there is a file editor for ubuntu that is faster than default editor (even when opening the compressed file .gz)? what do you suggest? |
July 10, 2020, 13:42 |
Adhiraj
Rep Power: 16 |
I assume that you are trying to edit boundary conditions in the file. Have you tried using the vi editor?
Please note that on Ubuntu you need to install the vim package to get a fully functioning vi editor. |
July 12, 2020, 15:45 |
Rep Power: 7 |
thanks a lot, I'll try this
July 13, 2020, 04:01 |
Tarang
Rep Power: 15 |
I mostly use vim text editor. It is bit tricky to use but once you get a hang of it, you enjoy it very well.
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 17:05 |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 09:46 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
How to setup a simple OpenFOAM cluster? | TommiPLaiho | OpenFOAM Installation | 3 | October 27, 2013 16:15 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 15:25 |
