June 25, 2020, 03:04 |
resume simulation - p_rgh not stored
Piotr Ładyński
Rep Power: 9 |
I stopped my chtMultiRegionFoam simulation after 2 days to check, how the flow field progresses, but i can't resume it now form the latestTime.
Each core screams error: Code:
[2] --> FOAM FATAL ERROR: [2] previous iteration field IOobject: volScalarField p_rgh local: "" readOpt: 0 writeOpt: 0 globalObject: 0 "/home/mecht/heater001/zoneSource/processor2/300/water" not stored. Use field.storePrevIter() at start of iteration. Problem solved (logs, logs, logs!): Initially (two days ago) i started my simulation with the same input for fvSolution for the water region and for the fvSolution in the system folder, then I realized, that the solver loops for unreasonable amounts of loops within the single timestep, because it solved pimple algorithm loops again over the solved pimple loops inside each region (?), or something like this. I changed my system/fvsolution pimple input to PIMPLE {//empty} and it worked just fine. I couldn't recall that change today, and it seems that my initial settings were required to initiate my simulation. Last edited by piotr.mecht; June 25, 2020 at 04:10. Reason: Problem solved |
April 12, 2022, 15:36 |
Peter Forsyth
I came across the same error message (using reactingParcelFoam). It seems it *can* be an issue with the URF field/equation names not being explicitly defined (see https://bugs.openfoam.org/view.php?id=895). I commented out everything inside the relaxationFactors dictionary in fvSolution, and it now seems to run.
Posting just in case anyone else comes across this issue. |
How to resume a stopped simulation | Pallav | OpenFOAM Running, Solving & CFD | 28 | July 26, 2021 11:05 |
How to pause a transient simulation and resume without time step advancement? | aleisia | Main CFD Forum | 33 | June 12, 2017 11:41 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 02:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
Resume Transient simulation | HMR | CFX | 1 | June 28, 2011 21:13 |
