snappyHexMesh multiRegion failure
Like Tree3Likes
  • 3 Post By Rango
Old   June 22, 2020, 04:20
Default snappyHexMesh multiRegion failure
Zicheng Li
Liz1219 is on a distinguished road
Hi All!
I use OF4Win 18.10 then i have a CHT test case that failed to generate the multiregion grid with snappyHexMesh.
Well,there are fluid and solid grid domains are ultimately required
there is fluid.stl
solid.stl
there is snappyHexMeshDict
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
castellatedMesh on;
snap            on;
addLayers       off;
geometry
    fluid.stl
        type triSurfaceMesh;
		name fluid;
	solid.stl
		name solid;
	inlet.stl
		name inlet;
	outlet.stl
		name outlet;
castellatedMeshControls
    maxLocalCells 1000000;
    maxGlobalCells 20000000;
    minRefinementCells 0;
    maxLoadUnbalance 0;
    nCellsBetweenLevels 1;
    features
            file "fluid.eMesh";
            level 2;
            file "solid.eMesh";
            level 3;
            file "inlet.eMesh";
            level 2;
            file "outlet.eMesh";
            level 2;
    refinementSurfaces
        fluid
            level (1 2);
			faceZone fluid;
            cellZone fluid;
            cellZoneInside inside;
			insidePoint (30 25 0);
		solid
			level (2 3);
		    faceZone solid;
            cellZone solid;
			insidePoint (120 25 0);
		 inlet
			level (1 2);
			patchInfo
				type patch;
		outlet
			level (1 2);
			patchInfo
				type patch;
    resolveFeatureAngle 30;
    refinementRegions
    locationInMesh (120 25 0);
    allowFreeStandingZoneFaces true;
snapControls
    nSmoothPatch 5;
    tolerance 1.0;
    nSolveIter 300;
    nRelaxIter 10;
    nFeatureSnapIter 5;
    explicitFeatureSnap false;
    multiRegionFeatureSnap false;
    implicitFeatureSnap true;
addLayersControls
    relativeSizes true;
    layers
        "STL"
            nSurfaceLayers 1;
    expansionRatio 1.0;
    finalLayerThickness 0.3;
    minThickness 0.1;
    nGrow 0;
    featureAngle 30;
    slipFeatureAngle 30;
    nRelaxedIter 3;
    nRelaxIter 3;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedialAxisAngle 90;
    nMedialAxisIter 10;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
    additionalReporting false;
meshQualityControls
    maxNonOrtho 65;
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    maxConcave 80;
    minVol 1e-13;
    minTetQuality 1e-30;
    minArea -1;
    minTwist 0.02;
    minDeterminant 0.001;
    minFaceWeight 0.02;
    minVolRatio 0.01;
    minTriangleTwist -1;
    nSmoothScale 4;
    errorReduction 0.75;
    relaxed
        maxNonOrtho 75;
debug 0;
mergeTolerance 1e-6;
Howere ,there is no cell in my solid Zone
when i execute splitMeshRegions -cellZones -overwrite,it would generate a domain(blue) that i dont know how it got cut out.
And it makes me wonder and tired.Can anyone please guide me how to do
this? It would be a great help.
Thank you.
(Please send email to 2685306635@qq.com if you need mesh case folder)
Liz1219 is offline   Reply With Quote
Old   June 23, 2020, 04:45
Default Use topoSet / setSet
Thangasivam
namsivag is on a distinguished road
Try to use toposet. Follow the links to learn
https://www.youtube.com/watch?v=6bx1...iaQc3I&index=8
https://openfoamwiki.net/index.php/TopoSet
or
Try to use setSet. Follow the links to learn
https://www.youtube.com/watch?v=5PtNS1Nc_u0
https://openfoamwiki.net/index.php/SetSet
Cheers,
Sivam
namsivag is offline   Reply With Quote
Old   June 23, 2020, 11:39
Rango is on a distinguished road
Can you please share your snappyHexMesh log file? And also have you checked your "stl" files using "surfaceCheck" utiliy to see if they are closed?
Cheers
Rango is offline   Reply With Quote
Old   June 23, 2020, 11:56
Zicheng Li
Originally Posted by namsivag View Post
thank u bro,but this is my SHM-multiRegion test case,i dont wanna use toposet or setset. we will going to use compliex model with SHM-multiRegion ,right?I wonder it will hard to solve by sotoposet or setset .
best wishes!
Old   June 24, 2020, 01:02
Zicheng Li
Originally Posted by Rango View Post
Cheers
Hi Rango!
i sure that my "stl"files are closed by "surfaceCheck".I huaven't seen any cell in my solid zone and this is my snappyhexmesh.log file.
thank u bro!
Best Wishes!
Old   June 25, 2020, 08:17
First, as the snappyHexMesh log shows, the cellZone detection goes a bit off and selects two cellZones: "Fluid" and "Fluid-out", which the later is "Solid" plus a portion of the fluid around.
Just a few point:
1) You should remove the edge feature refinement for the sphere solid from "features" part since a sphere does not have any edge.
2) The same applies to the inlet and outlet edge features since they have already been captured in the fluid edge feature!
3) Also you'd better not to define inlet and outlet (or in general any surface patch) as separate geometry regions.
I have shared a test case for your geometry (maybe with different dimensions) which does the job using OpenFOAM-5.x:
sphereMultiRegion_case
Cheers
MoCFD, Liz1219 and wht like this.
Old   June 30, 2020, 06:09
Zicheng Li
Just a few point:
Cheers
thank u bro,thank u very much!I have benefits me a lot from your test case。
I get it!
Best wishes!
Old   March 5, 2021, 07:00
Default p_rgh devergence with chtMutiRegionFoam in first iteration
Zicheng Li
Hi all! The p_rgh appeared "nan" when my case is solved with chtMultiRegionFoam for fluid region in first iteration.I tried many ways, but still couldn't solve it.Now, I am very upset then wishing lovely people can give me some pertinent advice.Vielen Dank!
Well ,these my codes of fluid.Have a look ,please.
mesh
field p
FoamFile
version 2.0;
format ascii;
class volScalarField;
location 0/domain;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 101325;
boundaryField
domain_INLET
type calculated;
value $internalField;
domain_WALL
type calculated;
domain_OUTLET
type calculated;
domain_TOP
type calculated;
domain_to_left
type cyclicAMI;
domain_to_front
type cyclicAMI;
domain_to_right
type cyclicAMI;
domain_to_feet
type calculated;
domain_to_shoe
type calculated;
left_to_domain
type cyclicAMI;
left_to_shoe
type calculated;
front_to_domain
type cyclicAMI;
front_to_shoe
type calculated;
right_to_domain
type cyclicAMI;
right_to_shoe
type calculated;
field p_rgh
FoamFile
version 2.0;
format ascii;
location 0/domain;
object p_rgh;
boundaryField
domain_INLET
type fixedFluxPressure;
domain_WALL
domain_OUTLET
type uniformTotalPressure;
p0 $internalField;
domain_TOP
domain_to_left
type cyclicAMI;
domain_to_front
type cyclicAMI;
domain_to_right
type cyclicAMI;
domain_to_feet
domain_to_shoe
left_to_domain
type cyclicAMI;
left_to_shoe
front_to_domain
type cyclicAMI;
front_to_shoe
right_to_domain
type cyclicAMI;
right_to_shoe
field T
FoamFile
version 2.0;
format ascii;
location 0/domain;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
domain_INLET
type fixedValue;
domain_WALL
type zeroGradient;
domain_OUTLET
type inletOutlet;
inletValue $internalField;
domain_TOP
type zeroGradient;
domain_to_left
type cyclicAMI;
domain_to_front
type cyclicAMI;
domain_to_right
type cyclicAMI;
domain_to_feet
type compressible::turbulentTemperatureCoupledBaffleMix ed;
Tnbr T;
kappaMethod fluidThermo;
domain_to_shoe
Tnbr T;
left_to_domain
type cyclicAMI;
left_to_shoe
Tnbr T;
front_to_domain
type cyclicAMI;
front_to_shoe
Tnbr T;
right_to_domain
type cyclicAMI;
right_to_shoe
Tnbr T;
field U
FoamFile
version 2.0;
format ascii;
class volVectorField;
location 0/domain;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
domain_INLET
type surfaceNormalFixedValue;
refValue uniform -3;
domain_WALL
type noSlip;
domain_OUTLET
type pressureInletOutletVelocity;
domain_TOP
type noSlip;
domain_to_left
type cyclicAMI;
domain_to_front
type cyclicAMI;
domain_to_right
type cyclicAMI;
domain_to_feet
type noSlip;
domain_to_shoe
type noSlip;
left_to_domain
type cyclicAMI;
left_to_shoe
type noSlip;
front_to_domain
type cyclicAMI;
front_to_shoe
type noSlip;
right_to_domain
type cyclicAMI;
right_to_shoe
type noSlip;
field fvSchems
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system/domain";
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(div(phi,U)) Gauss linear;
div(phi,U) Gauss linearUpwindV grad(U);
div(phi,h) bounded Gauss upwind;
div(phid,p) bounded Gauss upwind;
div(phi,K) Gauss linear;
div(phi,k) bounded Gauss upwind;
div(phi,epsilon) bounded Gauss upwind;
div(phi,R) bounded Gauss upwind;
div((rho*R)) Gauss linear;
div(R) Gauss linear;
div(U) Gauss linear;
div(phi,muTilda) Gauss linear;
div(phi,Ekp) Gauss linear;
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear uncorrected;
interpolationSchemes
default linear;
snGradSchemes
default uncorrected;
fluxRequired
default no;
p;
wallDist
method meshWave;
field fvSolution
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
U
solver PBiCGStab;
smoother DILU;
preconditioner DILU;
tolerance 1e-6;
relTol 0.01;
nSweeps 2;
epsilon
solver PBiCGStab;
smoother DILU;
tolerance 1e-6;
relTol 0.01;
nSweeps 2;
h
solver PBiCGStab;
smoother DILU;
tolerance 1e-6;
relTol 0.01;
nSweeps 2;
k
solver PBiCGStab;
smoother DILU;
tolerance 1e-6;
relTol 0.01;
nSweeps 2;
p_rgh
solver GAMG;
smoother GaussSeidel;
preconditioner GaussSeidel;
tolerance 1e-6;
relTol 0.01;
nSweeps 2;
rho
solver smoothSolver;
tolerance 1e-5;
relTol 0.01;
nSweeps 2;
UFinal
$U;
relTol 0;
epsilonFinal
$epsilon;
relTol 0;
hFinal
$h;
relTol 0;
kFinal
$k;
relTol 0;
p_rghFinal
$p_rgh;
relTol 0;
rhoFinal
$rho;
relTol 0;
PIMPLE
momentumPredictor yes;
transonic no;
consistent no;
nOuterCorrectors 2;
nCorrectors 2;
nNonOrthogonalCorrectors 1;
residualControl
e 1e-3;
h 1e-3;
p 1e-2;
p_rgh 1e-3;
rho 1e-3;
t 1e-3;
turbulence 1e-3;
u 1e-4;
relaxationFactors
"p.*" 0.3;
p_rgh 0.3;
"rho.*" 0.1;
equations
"U.*" 0.7;
"h.*" 0.5;
"e.*" 0.5;
"(k|epsilon|omega|R|nuTilda|pollutant|epsilon) " 0.7;
T 0.5;
potentialFlow
nNonOrthogonalCorrectors 10;
PhiRefCell 0;
PhiRefValue 0;
cache
grad(U);
Thanks all!
multiregion, snappyhexmesh
[snappyHexMesh] Doubts regarding the use of snappyHexMesh for multiregion meshing Shibi OpenFOAM Meshing & Mesh Conversion 4 October 22, 2021 12:38
[snappyHexMesh] Multiregion snappyhexmesh obiscolly50 OpenFOAM Meshing & Mesh Conversion 0 April 18, 2019 01:51
snappyHexMesh axisymmetric multiRegion Henning86 OpenFOAM Running, Solving & CFD 0 October 23, 2014 13:05
[snappyHexMesh] SnappyHexMesh and MultiRegion - get regions from Salome to OF dzi OpenFOAM Meshing & Mesh Conversion 2 September 4, 2014 11:04
Simulation of SnappyHexMesh multiregion nithishgupta OpenFOAM Running, Solving & CFD 0 June 24, 2014 06:31
