JungHoon Lee
Rep Power: 7 ![]() |
Hi all,
I am currently writing my thesis using OpenFOAM as my tool. To do that, I need to describe background theories that I am currently using for the simulation as all other thesis do. However, it seems pretty hard to find out the right background theories, on which the implementations are based. For example, I am currently using reactingParcelFoam with phase change model from the film to air(evaporation). In the implementation, it uses "standardPhaseChange" model for the evaporation process. (https://www.openfoam.com/documentati...8H_source.html) However, it seems that it does not describe which theoretical model is used. Is there a document that describes all the theoretical backgrounds? Or am I the only one that cannot find it? Please let me know if you have any ideas or any comments ![]() Thanks so much for your help in advance! |
Tu Can
Rep Power: 9 ![]() |
physic theory: any physic book or fluent theory guide
mathematics theory: iterative methods for sparse linear systems combined: The OpenFOAM technology primer, mathematics, numerics, derivations and OpenFOAM that's what I know. ![]() |
Rep Power: 8 ![]() |
hi,
it is really hard to find ONE document that explains ALL the secret sauce with regards to the solvers, at least the more complex ones. i can't comment on the solver that you are interested in. i myself use the multiphase solvers, and for the theory behind the implementation i use theoretical books, phd/masters thesis etc. i also changed codes or added stuff, for that i compared how the theory is implemented in the code, so i checked and compared the mathematics with code syntax. i'm not an expert on algorithmic implementation (yet) but i know where to find what i need and change code to fit my needs. |
JungHoon Lee
Thank so much for your comments.
Well, usually, from the Openfoam configuration files, I can see some backgrounding models how it is implemented from it's name. However, in reactingParcelFoam, the phase-change model is named as "standardPhaseChange", which gives me confusion. (for phase change from liquid to gas, evporation) I am not such an expert in thermomechanics or thermodynamics but it is hard to find what the "standardPhaseChange" model is. Even in source code it is hard to find what that model is based on. Is there any other way to find it out? Thanks! |
Anup Singh
Rep Power: 6 ![]() |
I can't comment on your solver but you can try searching for PhD and Master thesis who have used the similar models from openfoam - they might mention the underlying principals or papers used. You can also look for Github page where they mention the changes made in the code as sometimes in those pages they also mention the reference papers they have used. You should can also look if Henry and Others have published any papers regarding this specific solver as there are few papers published by Henry and others which provide very powerful insight into the solvers implemented in openfoam.
Herpes Free Engineer
Rep Power: 12 ![]() |
If you can wait for the spring/summer of 2021, there will be an OpenFOAM primer written by Jasak, and one of his PhD graduates, Uroic, and released by Springer.
If you can't wait, you can consider to buy this book: The Finite Volume Method in Computational Fluid Dynamics: An Advanced Introduction with OpenFOAMŪ and Matlab. I think the reason why there is no canonical resource for OpenFOAM is the fact that developing and maintaining a documentation is as expensive as the implementation itself, or even more. Some of the links below could help as well.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 26 | June 21, 2024 06:54 |
Implementation of thermophoretic force in OpenFOAM | manu305 | OpenFOAM Programming & Development | 1 | March 31, 2022 19:14 |
OpenFOAM 5.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 11 | June 5, 2018 23:48 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 11:50 |
Understanding conjugate solver implementation in openfoam | umeshisode | OpenFOAM Programming & Development | 0 | February 9, 2015 06:17 |
