Dynamic Contact Angle Definition (dynamicAlphaContactAngle) |
May 22, 2020, 11:45 |
Mike Worth
Rep Power: 7 |
I'm trying to use a dynamicAlphaContactAngle boundary to 'pin' a contact point at the furthest that it reaches during advancement. As far as I understand dynamic contact angles this should work if the receding contact angle is zero, with a non-zero advancing contact angle.
I've tried setting this up to no avail, and having looked into the code it doesn't seem to do what I'd expect. The contact angle returned seems to be calcuated as: theta0_ + (thetaA_ - thetaR_)*tanh(uwall/uTheta_) At low velocity (uwall<<uTheta) the limit is theta0, which makes perfect sense. At high velocity in either direction (tanh(uwall/uTheta) = ±1)it doesn't limit to thetaA or thetaR as I'd expect. In fact thetaA and thetaR don't even seem to be independent parameters - only the difference between the two actually matters. Does anyone know why this is calculated the way it is? As far as I can tell, to get independent control of the three different angles I'd need to either overwrite this definition, or create a new boundary condition that behaves as I'd expect... |
May 26, 2020, 06:34 |
Mike Worth
Rep Power: 7 |
I've looked closer, and as far as I can tell the code for dynamicAlphaContactAngle doesn't behave at all as expected. At high velocity in either direction it doesn't tend towards the advancing or receding contact angle.
I don't think that there is a standard theory for exactly how to transition between advancing and receding angles (there doesn't seem to be anything in my textbook). Reusing the tanh approach, I think that this calculation gives results much more in line with what I'd expect: Code:
u_ratio=uWall/uTheta t=tanh(u_ratio) if u_ratio >= 0: return (1-t)*theta0 + t*thetaA else: return (1+t)*theta0 + -t*thetaR Unless anyone has an explanation I'll register this as a bug. Just having a bit of trouble with verifying my account on gitlab... And here is the implementation of my modified calculation: Code:
Foam::tmp<Foam::scalarField> Foam::dynamicAlphaContactAngleFvPatchScalarField::theta ( const fvPatchVectorField& Up, const fvsPatchVectorField& nHat ) const { if (uTheta_ < SMALL) { return tmp<scalarField>::New(size(), theta0_); } const vectorField nf(patch().nf()); // Calculated the component of the velocity parallel to the wall vectorField Uwall(Up.patchInternalField() - Up); Uwall -= (nf & Uwall)*nf; // Find the direction of the interface parallel to the wall vectorField nWall(nHat - (nf & nHat)*nf); // Normalise nWall nWall /= (mag(nWall) + SMALL); // Calculate Uwall resolved normal to the interface parallel to // the interface scalarField uwall(nWall & Uwall); Info << "USING MIKE WORTHS MODIFIED DYNAMIC CONTACT ANGLE CALCULATION\n"; //Calculation will likely give nonsense without warning if values do not satisfy thetaA>=theta0>=thetaR return theta0_ * (1 - tanh(uwall/uTheta_) * sign(uwall/uTheta_) ) - thetaA_ * neg(uwall) * tanh(uwall/uTheta_) + thetaR_ * pos(uwall) * tanh(uwall/uTheta_); //Original calculation: //return theta0_ + (thetaA_ - thetaR_)*tanh(uwall/uTheta_); } Last edited by MikeWorth; June 24, 2020 at 12:49. Reason: Fixed broken image link |
May 28, 2020, 05:20 |
Mike Worth
Rep Power: 7 |
I've also dug up this thread from last year, which was started with a bug report both that thetaA and thetaR are "the wrong way round" and that the limiting behaviour of the funciton is not to either thetaA or thetaR.
The discussion charged off into a dispute about which way round to define the angle, and missed the other (in my mind far less subjective) issue that the function ought to tend to one of them at each extreme... Bug reported: https://develop.openfoam.com/Develop.../-/issues/1746 Last edited by MikeWorth; June 24, 2020 at 12:46. Reason: Added bug link |
November 28, 2020, 10:30 |
Nice catch!
MS.slh
Hi Mike, Are you aware if this has been fixed/modified in the most recent version of OpenFOAM?
November 30, 2020, 04:00 |
Mike Worth
Rep Power: 7 |
The latest release version is 20.06; and if you look in the source code you can see that it is unchanged compared to my bug report.
Version 20.12 is due out in December, hopefully the change will be in there. If you really need it right now then you could swap in the appropriate lines from the bug report and recompile it yourself. |
December 1, 2020, 07:58 |
Thank you!
Alexander Yurishchev
Rep Power: 7 |
Do you know what is an acceptable value for uTheta could be? I choose 0.01 for my test case (sliding drops on the inclined surface) and it seems that both dynamic angles are the same as the static one.
Thanks! |
December 1, 2020, 10:09 |
MS.slh
uTheta is a scaling factor with same dimensions as velocity (LT^-1). It affects the rate at which the contact angle changes when the capillary number changes. I usually run the model without contact angle definition and see what is the range of velocity near to the wall at the interface and based on that will choose an appropriate scaling factor, uTheta. Maybe the name "uTheta" is misleading because it's a velocity not an angle/angular velocity.
December 2, 2020, 06:13 |
Complie
Rep Power: 7 |
Thank you for the guidance.
I am new to linux.. To my understanding I have to compile after I change .C file. Is there any relatively easy tutorial for how to do it properly? Alex. |
June 7, 2021, 02:53 |
#9 | |
A. Min
Rep Power: 12 |
Is this problem solved for OpenFOAM-v7? Or I should replace the above line on the code and recompile it? thanks |
June 7, 2021, 04:16 |
#10 |
Mike Worth
Rep Power: 7 |
Looking at the same line in v7 suggests that it also has the same bug - https://github.com/OpenFOAM/OpenFOAM...arField.C#L152
Making the same alteration and recompiling will probably work (I've not tried it, but it doesn't interact with much other code). After making the change run some very simple simulations and verify that the results are as expected. Probably also worth adding to the openfoam foundation bug-tracker to try and get it resolved in future versions. |
June 9, 2021, 02:01 |
#11 | |
A. Min
Rep Power: 12 |
Thanks for your answer. I replace that line with the code and recompiled it, however, I did not face a large difference in my results. Maybe in my case, that bug was not very important. My new question is related to uTheta. Could you please give me a more explanation about it? What is it? I read your statement "I usually run the model without contact angle definition and see what is the range of velocity near to the wall at the interface and based on that will choose an appropriate scaling factor, uTheta." but I didn't get it. without contact angle definition means you run the case with zeroGradient BC? I solved my case one time with uTheta = 2 and another time with uTheta = 0.01, and found that my case is very sensitive to the uTheta value. Thank you |
August 4, 2021, 05:20 |
#12 |
Rep Power: 8 |
Hi Mike, @MikeWorth
Can you please post the steps to reproduce this graph? How are you selecting a uWall from your patch, what is your criteria there? My understanding is that from all contact angles at the patch you take the max and min of those at each time step, Am I right? I am trying to validate the dynamic contact angle BC and came across your reported explanation. Thank you �� |
August 4, 2021, 12:09 |
#13 | |
Rep Power: 8 |
Can you please post the steps to reproduce this graph? How are you selecting a uWall from your patch, what is your criteria there? My understanding is that from all contact angles at the patch you take the max and min of those at each time step, Am I right? I am trying to validate the dynamic contact angle BC and came across your reported explanation. Thank you |
dynamic contact angle udf returns no value to solver | shiraz_man67 | Fluent UDF and Scheme Programming | 5 | July 3, 2018 15:51 |
multiphase flow - contact angle | manjunath88 | Fluent UDF and Scheme Programming | 6 | January 17, 2017 05:34 |
Dynamic Contact Angle UDF in Fluent | codyn | Fluent UDF and Scheme Programming | 2 | August 25, 2016 00:54 |
oil & water - dynamic contact angle | manxu | Fluent Multiphase | 3 | October 17, 2013 07:51 |
dynamic contact angle - oil & water | manxu | Fluent UDF and Scheme Programming | 0 | October 16, 2013 03:31 |
