How to multiply a field by another?
Like Tree1Likes
  • 1 Post By HPE
Old   May 16, 2020, 07:18
Default How to multiply a field by another?
Romain SL
rsaintlege is on a distinguished road
I'm trying to find a function to multiply a field by another but I can't find what I want.
However I found the functions 'sum' and 'subtract' so I'm assuming that it is possible to multiply fields as well with functions...
I also found the function 'scale' but it allows to multiply a field by a scalar only.
Any ideas?
rsaintlege is offline   Reply With Quote
Old   May 16, 2020, 15:13
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
- I assume you really meant `function object` by `function`.
- To my knowledge, there is no compiled FO for field multiplications, like there is `add`
- You can use `codedFunctionObject`s.
- You can modify an existing function object for your requirements.
Hope this helps for a start.
rsaintlege likes this.
HPE is offline   Reply With Quote
Old   May 17, 2020, 07:11
Romain SL
Thank you for your answer it helped me a lot. I tried to use codedFunctionObject and I wrote this (I'm not sure about it):
    compute_Power
        functionObjectLibs ( "libutilityFunctionObjects.so" );
        type coded;
        enabled true;
        redirectType Power;
	executeControl  writeTime;
	writeControl    writeTime;
        code
            const volScalarField& T = mesh().lookupObject<volScalarField>("T");
            const volVectorField& U = mesh().lookupObject<volVectorField>("U");
            volScalarField Power
                IOobject
                    "Power",
                    mesh().time().timeName(),
                    Power.mesh(),
                    IOobject::NO_READ,
                    IOobject::AUTO_WRITE
                Power= 4185*1000*mag(U)*(T-293)
	    Power.write();
However, when I run the code, it seems to work fine but when I check the results in paraview, it appears that the field that I call "power" doesn't show up. Did I write something wrong or forget something in the code above?
Old   May 17, 2020, 10:39
Romain SL
This is finally the best I managed to do:
compute_Power
	    libs        ("libutilityFunctionObjects.so");
	    type coded;
	    name compute_Power;
	    outputControl  writeTime;
	    codeWrite
		    const volScalarField& h = mesh().lookupObject<volScalarField>("h");
		    const volScalarField& h_0 = mesh().lookupObject<volScalarField>("h_0");
		    volScalarField Power = 1000*mag(U)*(h-h_0);
		    Power.write();
That seems to work but the generated files don't have a real name, it's something like "(1000*mag(U)*(h-h_0))". Paraview cannnot therefore open those files. How can I name those files?
Old   May 17, 2020, 11:36
JNSN's Avatar
Jan
JNSN is on a distinguished road
Do you need this field just for post proccesing? Then you could also do this just in paraview.
JNSN is offline   Reply With Quote
Old   May 17, 2020, 12:08
Romain SL
Thank you for your answer.
Yes I just need it for post processing actually. How would you do to get this field with paraview? I previously did it by exporting the needed datas as csv files in Excel but I can't do it 100 times
I'm new on OpenFOAM so I don't really know what are the possibilities yet.
I'm still interested about making the previous function object work though. I think it would be more convenient, if you have an idea.
*EDIT*: I finally managed to do it with the 'calculator' option in Paraview
Old   September 28, 2021, 05:00
Thomas Michelon
thomas_mhn is on a distinguished road
Hi I'm also interested in making this kind of function.
Did you manage to change the name of the output file? I also have something like ( field1 * field2 ) as the name of the file.
thomas_mhn is offline   Reply With Quote
Old   May 22, 2023, 09:26
little_fish is on a distinguished road
i m still interested to use this postprocess function object, because i don t need to compute this field for each iteration, and i also need the field for calculation (so paraview is not the best option...)
here my coded function :
field_UthetaT
        type coded;
        name UthetaT;
        // executeControl  writeTime;
        // writeControl    writeTime;
        // region         region1;
        // patches         (cyclic1);
        codeWrite
            const volScalarField& Utheta = mesh().lookupObject<volScalarField>("Utheta.gz");
            const volScalarField& T = mesh().lookupObject<volScalarField>("T.gz");
            volScalarField UthetaT = Utheta * T;
            UthetaT.write();
and here the error i get when i use the function.
Create time
Create mesh for time = 20000
Using dynamicCode for functionObject field_UthetaT at line 3 in "functions.field_UthetaT"
Time = 20000
Reading fields:
Executing functionObjects
--> FOAM FATAL ERROR: (openfoam-2112 patch=220610)
    failed lookup of Utheta.gz (objectRegistry region0)
    available objects of type volScalarField:
0()
    From const Type& Foam::objectRegistry::lookupObject(const Foam::word&, bool) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]
    in file /usr/lib/openfoam/openfoam2112/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 463.
FOAM exiting
If someone could help me, it would be very cool.
Regards
little_fish is offline   Reply With Quote
Old   May 22, 2023, 09:29
ps: i did not write the function in the control dict because i have already some datas i need to postprocess, so i m using the following command :
postProcess -func field_UthetaT -latestTime
cordially
Old   May 24, 2023, 09:21
Chris Sideroff
cnsidero is on a distinguished road
Checkout multiply Class Reference
You can find an example of it in the openfoam.com tutorials:
$FOAM_TUTORIALS/incompressible/pisoFoam/RAS/cavity/system/FOs/FOmultiply
cnsidero is offline   Reply With Quote
Old   November 13, 2023, 17:24
Turhan
Turhan is on a distinguished road
compute_Power
	    type coded;
	    name compute_Power;
	    codeWrite
		    Power.write();
You have written this code, I have done something similar but I could not find the output values after doing the simulation.
I am not sure if my code is wrong or that I cannot find the output file from this code. Anyhow, I was wondering where I can find it, is it in the postprocessing file or in the ?
Turhan is offline   Reply With Quote
field, function, multiply
potential flows, helmholtz decomposition and other stuffs pigna Main CFD Forum 1 October 26, 2017 09:34
Access to field which is evaluated at the moment Tobi OpenFOAM Programming & Development 6 April 19, 2017 14:09
[General] How to create an additional vector with {Field 4, Field 5, Field 6} Bombacar ParaView 1 August 15, 2015 19:05
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
