Harris Snyder
Rep Power: 8 ![]() |
Hi everyone, is it possible to change the format of an existing case (all time steps) from ASCII format to binary format? If so, how?
Thanks. |
Rep Power: 15 ![]() |
There is a utlitiy -- foamFormatConvert -- that from the description can be used to convert from binary to ascii (https://github.com/OpenFOAM/OpenFOAM...ormatConvert.C). It is worth checking if it works the other way too -- I've not tried to do so.
Caelan |
Harris Snyder
That worked! All I had to do was change writeFormat in the controlDict and run foamFormatConvert, and it converted the whole case to binary. Thank you!
Simon
Rep Power: 6 ![]() |
I also found a online service to do that if you are still interessted:
https://www.meshconvert.com/de.html |
LES case diverges after 5 flow-through-time | mcshidada | OpenFOAM Running, Solving & CFD | 2 | July 17, 2018 21:50 |
Help resolving simple case in buoyantSimpleFoam | sturgeon | OpenFOAM Running, Solving & CFD | 1 | November 7, 2017 12:49 |
Opening an existing case with OF for Windows | MaxMarschall | OpenFOAM Running, Solving & CFD | 1 | December 6, 2016 11:29 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 08:42 |
