Found uncovered faces for GGI interface
Like Tree1Likes
  • 1 Post By BSengupta
Old   October 28, 2019, 05:07
Default Found uncovered faces for GGI interface
Bidesh Sengupta
BSengupta is on a distinguished road
Hi! Foamers,
I am trying to run overlapGgi and getting the error as:
--> FOAM FATAL ERROR:
Found uncovered faces for GGI interface innercylinder/outercylinder
This is an unrecoverable error. Aborting.
boundary
blade_1
type wall;
nFaces 46561;
startFace 5183059;
blade_2
type wall;
nFaces 39728;
startFace 5229620;
innercylinder
type overlapGgi;
nFaces 41878;
startFace 5269348;
rotationAxis (0 0 1);
nCopies 30;
shadowPatch outercylinder;
zone innercylinder_faces;
outercylinder
type overlapGgi;
nFaces 41880;
startFace 5326982;
nCopies 30;
shadowPatch innercylinder;
zone outercylinder_faces;
farfield
type patch;
nFaces 15756;
startFace 5311226;
setBatch
faceSet innercylinder_faces new patchToFace innercylinder
faceSet outercylinder_faces new patchToFace outercylinder
cellSet rotor new cellToCell cellRegion0
quit
dynamicMeshDict
dynamicFvMeshLib "libtopoChangerFvMesh.so";
dynamicFvMesh turboFvMesh;//mixerGgiFvMesh;
turboFvMeshCoeffs//mixerGgiFvMeshCoeffs
coordinateSystem
type cylindrical;
origin (0 0 0);
axis (0 0 1);
direction (1 0 0);
rpm
cellRegion0 360;
cellRegion1 0.0;
slider
insidecylinder_faces 360;
MRFZones
cellRegion0//rotor
nonRotatingPatches (farfield);
origin origin [0 1 0 0 0 0 0] (0 0 0);
axis axis [0 0 0 0 0 0 0] (0 0 1);
omega omega [0 0 -1 0 0 0 0] 360;
Command
regionCellSets
setSet -batch setBatch
setsToZones -noFlipMap
solverName
Can any one tell me how to resolve this error.
The figure shows blade1, blade2 and innercylinder.
Thanks a lot.
BSengupta is offline   Reply With Quote
Old   October 29, 2019, 00:51
Bidesh Sengupta
any answer please
Old   October 29, 2019, 22:19
Bidesh Sengupta
I solved the issue using ggi instead of overlapGgi.
The sample is given below:
cylr
type ggi;
nFaces 1656;
startFace 9801445;
nCopies 30;
shadowPatch cyls;
zone cylr_faces;
bridgeOverlap true; //This was also important.
cyls
type ggi;
nFaces 1656;
startFace 9829183;
nCopies 30;
shadowPatch cylr;
zone cyls_faces;
bridgeOverlap true;
Thank you.
Bidesh
galoisati likes this.
foam ext 4.0, ggi, openfaom
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 08:05
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 06:29
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
