Promblem in compiling foam-extend-"recipe for target 'foam.out' failed"
Like Tree1Likes
  • 1 Post By hjasak
Old   October 13, 2019, 01:28
Default Promblem in compiling foam-extend-"recipe for target 'foam.out' failed"
Bidesh Sengupta
BSengupta is on a distinguished road
Hi! Foamers.
Hope you all are doing very good.
I am facing a strange error while compiling src folder in foam-extend.
The error is:
g++-5 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I/home/bidesh/foam/foam-extend-4.0/src/finiteVolume/lnInclude -I/home/bidesh/foam/foam-extend-4.0/src/meshTools/lnInclude -I/home/bidesh/foam/foam-extend-4.0/src/thermophysicalModels/basic/lnInclude -I/home/bidesh/foam/foam-extend-4.0/src/turbulenceModels/compressible/turbulenceModel -I/home/bidesh/foam/foam-extend-4.0/ThirdParty/packages/ParMGridGen-1.0/platforms/linux64GccDPOpt/include/IMlib -I/home/bidesh/foam/foam-extend-4.0/ThirdParty/packages/ParMGridGen-1.0/platforms/linux64GccDPOpt/include/Lib -IlnInclude -I. -I/home/bidesh/foam/foam-extend-4.0/src/foam/lnInclude -I/home/bidesh/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/roeFlux.o Make/linux64GccDPOpt/rusanovFlux.o Make/linux64GccDPOpt/betaFlux.o Make/linux64GccDPOpt/hllcFlux.o Make/linux64GccDPOpt/hllcALEFlux.o Make/linux64GccDPOpt/roeDropletFlux.o Make/linux64GccDPOpt/roeIceFlux.o Make/linux64GccDPOpt/basicNumericFlux.o Make/linux64GccDPOpt/newBasicNumericFlux.o Make/linux64GccDPOpt/numericFluxes.o Make/linux64GccDPOpt/basicNumericFlux1.o Make/linux64GccDPOpt/newBasicNumericFlux1.o Make/linux64GccDPOpt/numericFluxes1.o Make/linux64GccDPOpt/basicNumericIceFlux.o Make/linux64GccDPOpt/newBasicNumericIceFlux.o Make/linux64GccDPOpt/numericIceFluxes.o Make/linux64GccDPOpt/mgMeshLevel.o Make/linux64GccDPOpt/fineMgMeshLevel.o Make/linux64GccDPOpt/coarseMgMeshLevel.o Make/linux64GccDPOpt/mgFieldLevel.o Make/linux64GccDPOpt/fineMgFieldLevel.o Make/linux64GccDPOpt/coarseMgFieldLevel.o Make/linux64GccDPOpt/localTimeStep.o Make/linux64GccDPOpt/backwardDualDdtSchemes.o Make/linux64GccDPOpt/EulerLocalDdtSchemes.o -L/home/bidesh/foam/foam-extend-4.0/lib/linux64GccDPOpt \
-lfoam -ldl -lrt -lm -o foam.out
I am not getting much idea about this error. Can anyone tell me about this error.
Thanks a lot.
BSengupta is offline   Reply With Quote
Old   October 14, 2019, 03:18
Hrvoje Jasak
Type
wmake libso
instead of
wmake
Tolga KURUMUS likes this.
Hrvoje Jasak
Old   October 14, 2019, 20:33
Bidesh Sengupta
Thank you very much. The problem is solved.
compilation error, dbns, foam ext 4.0, solver
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 03:21
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
