how to run rivuletPanel with simpleReactingParcelFoam instead of ReactingParcelFoam? |
Hello Foamers,
I realized OpenFOAM v-6 has two foam solvers, which are 'simpleReactingParcelFoam' and 'reactingParcelFoam', under Lagrangian folder. and inside 'simpleReactingParcelFoam' there is only one case, which is 'verticalChannel', while inside 'reactingParcelFoam', there are many cases and one of them is 'rivuletPanel' case. So, my question is how to convert rivuletPanel and run with steady state solver, which is 'simpleReactingParcelFoam' instead of transient solver 'reactingParcelFoam'? Because, I believe that all these cases under 'reactingParcelFoam' can be run with 'simpleReactingParcelFoam'. Also, can in-compressible flow model with 'simpleReactingParcelFoam' or 'reactingParcelFoam'? |
lagrangian, reactingparcelfoam, rivuletpanel, simplereactingparcelfoam |
fatal overflow error in the FINMES subroutine for CHT run | prashant79_ss | CFX | 5 | September 27, 2014 04:54 |
Cannot run phoenix on linux opensuse 13.1 kde | mabal | Phoenics | 0 | June 15, 2014 06:16 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 11:20 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 12:08 |
Windows 64-bit, Distributed Parallel Run Issues... | Erich | CFX | 3 | March 28, 2006 16:36 |
