June 9, 2019, 13:58 |
Naming regions in stl file for snappyHexMesh
Kaushik
Rep Power: 7 |
Hi all,
I am relatively new to OpenFOAM, and need some help in creating an stl file with named regions. I am trying to model scalar transport in an arbitrary geometry. For starters, if I had to mesh the region inside a cylinder using snappyHexMesh, with defined inlet, outlet and wall to assign boundary conditions, how should I go about this? Thanks. |
June 10, 2019, 10:38 |
Damian Berghof
Rep Power: 11 |
Hi kauraajn,
that's not really rocket science and you will find everything about this topic in the forum here. You can use the 'Search' function to get it. 1.) Just few examples what's already available: Creating waterproof STL using snappyHexMesh or salome (obligatory to read and to understand) Giving patch names within stl files how to define patches with snappyHexMesh from a STL file ? Patch Names in STL file for snappyHexMesh snappyHexMesh - different patch names from stl file etc. 2.) Check free available OS Software for STL creation and meshing: 'Salome Meca' and 'FreeCAD' 3.) Use exisitng Linux commands to manipulate and check ASCII STL files cat, split, grep, ... 4.) and OpenFOAM utilities https://cfd.direct/openfoam/user-gui...#x14-1090003.6 surfaceAutoPatch, surfaceRefineRedGreen, surfaceCheck, ... 5.) Use 'ParaView' to check your STL geometry 6.) Start with some simple tutorials, e.g. 'motorBike', 'elbow' And let me know if you need more support ... Damian |
August 14, 2019, 12:29 |
Kaushik
Rep Power: 7 |
Sorry for the late acknowledgement, but thank you so much Damian. This was really helpful
named regions, snappyhexmesh, stl format |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
