Calculate mass flow rate during run time in OpenFOAM
Like Tree5Likes
  • 4 Post By jherb
  • 1 Post By Yann
Old   May 21, 2019, 17:27
Default Calculate mass flow rate during run time in OpenFOAM
Aishwarya Krishnan
aishk is on a distinguished road
Hi all!
I am using the icoUncoupledKinematicParcel solver for a simple hopper-particle simulation. I have used "manual injection" and I need the mass flow rate through a specific plane in the hopper during its emptying. But when I try to do it through ParaView, I get U(0,0,0) (if I use slice -> integrate variables -> calculator). Does anyone know how to calculate the value of U or MFR through a plane or rectify this error?
Thanks for any help!
aishk is offline   Reply With Quote
Old   May 22, 2019, 10:00
Joachim Herb
jherb is on a distinguished road
You could add a function to system/controlDict which outputs the massflow in the directory postProcessing:
functions
   outletMassFlowYourPatch
        type            surfaceFieldValue;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled         true;
        writeControl    timeStep;
        writeInterval   100;
        log             true;
        writeFields     false;
        regionType      patch;
        name            yourPatch;
        operation       sum;
        fields
            phi
If you want do this on a plane inside the fluid domain, you could try an internal baffle.
jherb is offline   Reply With Quote
Old   May 23, 2019, 19:41
Aishwarya Krishnan
Hi @jherb,
I tried both these options. I still get phi=0 at each time step in the outlet file.
Any other way to solve this?
Thank you!
Old   May 24, 2019, 05:11
Joachim Herb
Which version of OpenFOAM are you using? Have a look at the source code of your solver (icoUncoupledKinematicParcel?) and check which field is used the flux. Then use that field in the functions object. Also did you get a postProcessing folder at all? The example I gave you outputs the values only every 100th time step. Change the value of writeInterval to 1.
Old   May 24, 2019, 13:45
Aishwarya Krishnan
I am using OpenFOAM-dev for ubuntu. It looks like phi is velocity,U in icoUncoupledKinematicParcel.
I did get a postProcessing folder but all values of phi were zero at each 100 timesteps. Even when I reduce the timesteps to 1 it is zero.
I am not sure what is wrong. The magnitude of U in paraView is not zero though. The particles have velocity.
Old   May 27, 2019, 08:03
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello aishk,
In the example given by jherb, the function object computes the fluid flowrate, since phi refers to the fluid flux. The flux might be 0 in your case if you have a static fluid and if particles are just transported thanks to gravity and/or injection velocity. (this is what happens in the original hopper tutorial)
Since you want data related to particles, you need to use cloudFunctions, which are defined in your kinematicCloudProperties file. Among other cloud functions, facePostProcessing might do what you want :
Class
    Foam::FacePostProcessing
Description
    Records particle face quantities on used-specified face zone
    Currently supports:
        accummulated mass
        average mass flux
To use it, you need to define your plane as a faceZone (ie using topoSet) and then define the facePostProcessing function in your kinematicCloudProperties:
cloudFunctions
    myPostProcessing1
        type            facePostProcessing;
        surfaceFormat    none;
        resetOnWrite    no;
        log                yes;
        faceZones
            myPlaneFaceZone
You can switch off the "resetOnWrite" depending on whether you want the accumulated mass since start or since last write.
Have fun,
Yann
Antus likes this.
Yann is offline   Reply With Quote
mass flow rate, openfoam 1.5-dev, postprocessing mass flow
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 07:00
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 06:58
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Exit Corrected Mass Flow Rate Mesh Sensitivity Study s__s__s CFX 4 July 20, 2016 12:46
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 14:14
