NACA 2412 airfoil fail with SST but works with k-Epsilon. What I'm doing wrong?
Like Tree3Likes
  • 1 Post By CsabiH
  • 1 Post By yambanshee
  • 1 Post By mzzmrt
Old   April 28, 2019, 13:59
Default NACA 2412 airfoil fail with SST but works with k-Epsilon. What I'm doing wrong?
Csaba Hetyei
CsabiH is on a distinguished road
Hi!
I think it's a noob question but I cannot find the "why".
I was trying to run the same simulation (NACA 2412 airfoil with different AOAs) with k-Epsilon and k-OmegaSST. For the k-Epsilon I was able to run all of my simulation (between AOA 0°-18°), but for the SST all was failing (The simulation files is here: https://github.com/HetyCs/space/blob/master/sst2.zip )
Does it happen with anyone else? Maybe somebody know why it's happen?
Details:
Mesh are imported from Fluent, I run in steady state, some details came from the OpenFOAM's arifoil tutorial others from various sources (finding with google).
First time when I run in parallel, I got always this message (I was tried to run in 8, 4 and 2 core on two different PC):
Time = 7
DILUPBiCGStab: Solving for Ux, Initial residual = 0.6190897, Final residual = 0.01558434, No Iterations 2
DILUPBiCGStab: Solving for Uy, Initial residual = 0.6421446, Final residual = 0.03402597, No Iterations 2
DILUPBiCGStab: Solving for Uz, Initial residual = 0.01623852, Final residual = 0.001378081, No Iterations 1
GAMG: Solving for p, Initial residual = 0.2421197, Final residual = 0.02305116, No Iterations 4
GAMG: Solving for p, Initial residual = 1, Final residual = 0.005137695, No Iterations 1
time step continuity errors : sum local = 6.253806e+25, global = -5.842945e+10, cumulative = -5.842945e+10
DILUPBiCGStab: Solving for omega, Initial residual = 0.5883746, Final residual = 0.01695568, No Iterations 1
bounding omega, min: -9.2748e+17 max: 3.077731e+18 average: 1.562023e+14
DILUPBiCGStab: Solving for k, Initial residual = 0.2610974, Final residual = 0.01608745, No Iterations 1
ExecutionTime = 12.19 s ClockTime = 12 s
Time = 8
DILUPBiCGStab: Solving for Ux, Initial residual = 0.7223081, Final residual = 0.05084051, No Iterations 1
DILUPBiCGStab: Solving for Uy, Initial residual = 0.7184469, Final residual = 0.0513341, No Iterations 1
DILUPBiCGStab: Solving for Uz, Initial residual = 0.7743565, Final residual = 0.05029539, No Iterations 1
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[53576,1],0]
Exit code: 142
cs@DESKTOP-2DMKBPC:~/OpenFOAMW/sst2$
When I try to run in serial, the simulation ended at the 8th iteration without any error message.
Time = 7
DILUPBiCGStab: Solving for Ux, Initial residual = 0.6844985, Final residual = 0.05382421, No Iterations 1
DILUPBiCGStab: Solving for Uy, Initial residual = 0.6899303, Final residual = 0.04158705, No Iterations 1
DILUPBiCGStab: Solving for Uz, Initial residual = 0.6400409, Final residual = 0.06345476, No Iterations 1
GAMG: Solving for p, Initial residual = 0.334632, Final residual = 0.0265109, No Iterations 3
GAMG: Solving for p, Initial residual = 1, Final residual = 0.03916845, No Iterations 1
time step continuity errors : sum local = 3.808465e+24, global = -1.037842e+09, cumulative = -1.037842e+09
DILUPBiCGStab: Solving for omega, Initial residual = 0.03670445, Final residual = 0.003059216, No Iterations 4
bounding omega, min: -2.270383e+16 max: 3.898286e+16 average: 1.93997e+13
DILUPBiCGStab: Solving for k, Initial residual = 0.1322971, Final residual = 0.007287265, No Iterations 1
ExecutionTime = 11.64 s ClockTime = 12 s
Time = 8
DILUPBiCGStab: Solving for Ux, Initial residual = 0.7391198, Final residual = 0.0301078, No Iterations 1
DILUPBiCGStab: Solving for Uy, Initial residual = 0.7285467, Final residual = 0.03929454, No Iterations 1
DILUPBiCGStab: Solving for Uz, Initial residual = 0.7519563, Final residual = 0.0528125, No Iterations 2
silver.blaze likes this.
Csabi
CsabiH is offline   Reply With Quote
Old   April 29, 2019, 04:15
Zander Meiring
yambanshee is on a distinguished road
Looking at your pressure residual, you are getting a diverging solution. What is your mesh quality parameters (run the command checkMesh in the case dictionary) and your boundary conditions?
CsabiH likes this.
yambanshee is offline   Reply With Quote
Old   April 29, 2019, 14:25
mzzmrt is on a distinguished road
Your case has many problems such as boundary conditions and mesh.
You have a 2D (pseudo 3D) case and you have to use "empty" boundary condition for sides not "symmetry". Also be careful for inlet and outlets etc.
You can check the airfoil2D case for a correct setup.
For meshing this type of work it's far better to use another open-source tool "Construct2D" instead of Gmsh.
CsabiH likes this.
mzzmrt is offline   Reply With Quote
Old   April 30, 2019, 09:35
Csaba Hetyei
Dear mzzmrt and yambanshee,
Thanks for your ideas. I could run the simulations with new solver options and the empty BC.
Thank you
Csabi
2D NACA 0012 Airfoil Validation Case (NASA) jp3g12 OpenFOAM Running, Solving & CFD 24 April 23, 2021 15:34
udf error srihari FLUENT 1 October 31, 2016 15:18
NACA 2412 simulation in CFX - 2nd Run andrew CFX 12 December 18, 2013 09:34
Flow over an airfoil using Realizable K Epsilon jp3g12 OpenFOAM Running, Solving & CFD 16 June 14, 2013 09:16
K - epsilon VS SST turbulence model Maicol Main CFD Forum 0 November 30, 2012 17:25
