April 26, 2019, 15:26 |
PisoFoam error: mpirun Exit Code
Joe lee
Rep Power: 8 |
Recently, I tried to run my simulation using simpleFoam, but then I found the residual and forceCoeffs fluctuate a lot, so I think it may have a transient solution, and then switched to pisoFoam.
I kept most of the file unchanged, except: controlDict(change from "simpleFoam" to "pisoFoam"), fvSchemes(modified using $FOAM_TUTORIALS/incompressible/pisoFoam/RAS/cavity as reference), fvSolution(same as above) Then I tried to run it again, but the pisoFoam went wrong. It aborted, but I have no idea what is the cause. The log.pisoFoam: Code:
-------------------------------------------------------------------------- WARNING: Linux kernel CMA support was requested via the btl_vader_single_copy_mechanism MCA variable, but CMA support is not available due to restrictive ptrace settings. The vader shared memory BTL will fall back on another single-copy mechanism if one is available. This may result in lower performance. Local host: AdminPC -------------------------------------------------------------------------- /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : dev-becf7d290547 Exec : pisoFoam -parallel Date : Apr 27 2019 Time : 02:15:36 Host : "AdminPC" PID : 656 I/O : uncollated Case : /home/taeioum/OpenFOAM/taeioum-dev/run/constantMovingTest/c3t nProcs : 6 Slaves : 5 ( "AdminPC.657" "AdminPC.658" "AdminPC.659" "AdminPC.660" "AdminPC.661" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present No finite volume options present Starting time loop streamLine streamLines: automatic track length specified through number of sub cycles : 5 [AdminPC:00651] 5 more processes have sent help message help-btl-vader.txt / cma-permission-denied [AdminPC:00651] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Reading surface description: yNormal forces forceCoeffs1: Not including porosity effects forceCoeffs forceCoeffs1: Not including porosity effects Time = 0.05 Courant Number mean: 0.0135004 max: 0.861136 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 7.22412e-06, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 9.52946e-06, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 5.33646e-06, No Iterations 5 ------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code.. Per user-direction, the job has been aborted. ------------------------------------------------------- -------------------------------------------------------------------------- mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[9700,1],3] Exit code: 145 -------------------------------------------------------------------------- |
April 26, 2019, 18:26 |
Joe lee
Rep Power: 8 |
The problem seems to be solved by reducing the timestep.
Originally I got a deltaTime of 0.05s, and now I got 0.005s. The calculation is now able to proceed. Is there any timestep limitation on pisoFoam? Or did I just solve this problem with luck? |
April 29, 2019, 06:17 |
Robert
Rep Power: 12 |
Yes, it's called the Courant number. The values has to stay below 1.0.
If you liked my answer to your question, please consider leaving a "Like" in return |
April 29, 2019, 08:10 |
Joe lee
Rep Power: 8 |
Error "Non-zero Exit code of :2 " | KushNepal | CFX | 13 | December 12, 2016 04:36 |
error mesage " exited normally and returned an exit code of 0 " | raunakjung | Main CFD Forum | 1 | October 18, 2016 11:56 |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 13:30 |
Solver exit return code 1 | acvq | CFX | 5 | September 11, 2011 10:06 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 11:11 |
