Problem with createBaffles - want to make master and slave internal patches
Like Tree1Likes
  • 1 Post By artymk4
Old   April 25, 2019, 05:04
Default Problem with createBaffles - want to make master and slave internal patches
Martin
artymk4 is on a distinguished road
I'm using foam-extend-4.0 so createBaffles utility needs to be run without createBafflesDict file the way it was done in OF2.1: https://openfoamwiki.net/index.php/CreateBaffles
I have faceZone which I want to convert to internal patch which will not impact flow. So I need to make two patches of type cyclic (master and slave).
When I run
createBaffles CK "(CK1 CK2)"
I get this:
Create time
Create mesh for time = 0
--> FOAM Warning :
    From function polyMesh(const IOobject&)
    in file meshes/polyMesh/polyMesh.C at line 348
    no points in mesh
Converting faces on zone CK into baffles.
Found 896 faces on zone CK
--> FOAM FATAL ERROR:
Cannot find patch (CK1 CK2)
Valid patches are
17
inlet
outlet
casing_shroud-fluid_outlet
casing_shroud-fluid_inlet
casing_hub-fluid_outlet
casing_hub-fluid_inlet
ck_shroud
ck_hub
ck_blade_le
ck_blade_ps
ck_blade_ss
ck_blade_te
cyclic1
cyclic2
cyclic3
CK1
CK2
    From function findPatchID(const polyMesh&, const word&)
    in file createBaffles.C at line 113.
FOAM exiting
As you can see, I did create two new patches CK1 and CK2 in 'boundary' file. However it seems like createBaffles is expecting only one patch and I can't make it accept two.
I also tried to use -additionalPatches option, but no luck.
createBaffles works this way: createBaffles CK CK1, but then I am missing CK2 and I cannot set type cyclic to patch CK1.
Please help.
the_ichthyologist likes this.
artymk4 is offline   Reply With Quote
Old   May 22, 2021, 06:45
Tommaso
evxta3 is on a distinguished road
Hi, did anyone solve the problem?
evxta3 is offline   Reply With Quote
additionalpatches, createbaffles, foam-extend-4.0, internal face, master slave
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
big difference between clockTime and executionTime LM4112 OpenFOAM Running, Solving & CFD 21 February 15, 2019 04:05
foam-extend-3.2 Pstream: "MPI_ABORT was invoked" craven.brent OpenFOAM Running, Solving & CFD 5 November 18, 2015 08:55
Conjugate heat transfer sunilpatil CFX 1 January 25, 2013 12:42
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
