yPlusRAS command not found
Like Tree12Likes
  • 1 Post By Jinjolee
  • 8 Post By Yann
  • 3 Post By Jinjolee
Old   April 15, 2019, 09:17
Default yPlusRAS command not found
Joe lee
Jinjolee is on a distinguished road
I would like to check the y plus value in openFoam, and I found that it would be done using yPlusRAS command. However, it seems that I do not have this command in my version. Is yPlusRAS an external command required installation? Thanks
shouvik ghorui likes this.
Jinjolee is offline   Reply With Quote
Old   April 15, 2019, 09:31
Yann
Yann will become famous soon enoughYann will become famous soon enough
The yPlusRAS is indeed outdated. Try something like :
simpleFoam -postProcess -func yPlus
Replace "simpleFoam" with the name of your solver if you used another one, and "mpirun" with "-parallel" option if you want to execute it in parallel.
Yann
Yann is offline   Reply With Quote
Old   April 15, 2019, 10:37
Joe lee
Yann
Thanks a lot. This solved my problem.
y plus
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 16:11
injection problem Mark New FLUENT 0 August 4, 2013 02:30
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 02:36
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
