Motorboat sinkage/trim and resistance
Like Tree1Likes
  • 1 Post By AdrianM
Old   February 1, 2019, 14:56
Default Motorboat sinkage/trim and resistance
AdrianM is on a distinguished road
Hi everyone ,
i am new to OpenFoam.
I am trying to calculate the trim angle/sinkage and resistance of a motor boat as a first step. My final calculation should include a propulsion of the motor boat interacting on the trim angle and sinkage.
As a Beginner I first took a look at the DTCHullMoving tutorial (OpenFoam 6), to check and get some experience on how this is working.
After that I included my Mesh from Ansys containing my hull and boundaries. Unfortunately I am getting errors (I am guessing because of the sixDoFRigidBodyMotion) but I can't figure out how to solve it.
I would be very thankful if somebody could help me out here
Here is the log.interFoam file:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
Build : 6-6257b17a4cf8
Exec : interFoam -parallel
Date : Feb 01 2019
Time : 19:25:57
Host : "adrian"
PID : 14894
I/O : uncollated
Case : /home/adrian/OpenFOAM/adrian-6/run/TFB
nProcs : 8
Slaves :
7
"adrian.14895"
"adrian.14896"
"adrian.14897"
"adrian.14898"
"adrian.14899"
"adrian.14900"
"adrian.14901"
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: rigidBodyMotion
Selecting rigidBodySolver Newmark
PIMPLE: No convergence criteria found
PIMPLE: No corrector convergence criteria found
Calclations will do 3 corrections
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
RAS
RASModel kOmegaSST;
turbulence on;
printCoeffs on;
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.000434825, No Iterations 10
time step continuity errors : sum local = 8.47695e-10, global = 1.0359e-10, cumulative = 1.0359e-10
Constructing face velocity Uf
Courant Number mean: 0.0105543 max: 5.1944
forces forces:
Not including porosity effects
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.0011999
Time = 0.0011999
PIMPLE: Iteration 1
forces forces:
[0] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[0] #1 Foam::sigFpe::sigHandler(int) at ??:?
[0] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3 Foam::RBD::rigidBodyModel::forwardDynamics(Foam::R BD::rigidBodyModelState&, Foam::Field<double> const&, Foam::Field<Foam::SpatialVector<double> > const&) const at ??:?
[0] #4 Foam::RBD::rigidBodyMotion::forwardDynamics(Foam:: RBD::rigidBodyModelState&, Foam::Field<double> const&, Foam::Field<Foam::SpatialVector<double> > const&) const at ??:?
[0] #5 Foam::RBD::rigidBodySolvers::Newmark::solve(Foam:: Field<double> const&, Foam::Field<Foam::SpatialVector<double> > const&) at ??:?
[0] #6 Foam::RBD::rigidBodyMotion::solve(double, double, Foam::Field<double> const&, Foam::Field<Foam::SpatialVector<double> > const&) at ??:?
[0] #7 Foam::rigidBodyMeshMotion::solve() at ??:?
[0] #8 Foam::motionSolver::newPoints() at ??:?
[0] #9 Foam::dynamicMotionSolverFvMesh::update() at ??:?
[0] #10 ? in "/opt/openfoam6/platforms/linux64GccDPInt32Opt/bin/interFoam"
[0] #11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #12 ?[adrian:14894] *** Process received signal ***
[adrian:14894] Signal: Floating point exception (8)
[adrian:14894] Signal code: (-6)
[adrian:14894] Failing at address: 0x3e800003a2e
[adrian:14894] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f92aa288f20]
[adrian:14894] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f92aa288e97]
[adrian:14894] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7f92aa288f20]
[adrian:14894] [ 3] /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/librigidBodyDynamics.so(_ZNK4Foam3RBD14rigidBodyMo del15forwardDynamicsERNS0_19rigidBodyModelStateERK NS_5FieldIdEERKNS4_INS_13SpatialVectorIdEEEE+0x169 8)[0x7f92857f09b8]
[adrian:14894] [ 4] /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/librigidBodyDynamics.so(_ZNK4Foam3RBD15rigidBodyMo tion15forwardDynamicsERNS0_19rigidBodyModelStateER KNS_5FieldIdEERKNS4_INS_13SpatialVectorIdEEEE+0x5e )[0x7f9285800b0e]
[adrian:14894] [ 5] /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/librigidBodyDynamics.so(_ZN4Foam3RBD16rigidBodySol vers7Newmark5solveERKNS_5FieldIdEERKNS3_INS_13Spat ialVectorIdEEEE+0x91)[0x7f9285807961]
[adrian:14894] [ 6] /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/librigidBodyDynamics.so(_ZN4Foam3RBD15rigidBodyMot ion5solveEddRKNS_5FieldIdEERKNS2_INS_13SpatialVect orIdEEEE+0xf0)[0x7f92857fe5b0]
[adrian:14894] [ 7] /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/librigidBodyMeshMotion.so(_ZN4Foam19rigidBodyMeshM otion5solveEv+0x971)[0x7f9285a3b301]
[adrian:14894] [ 8] /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/libdynamicMesh.so(_ZN4Foam12motionSolver9newPoints Ev+0x28)[0x7f92a903fae8]
[adrian:14894] [ 9] /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/libdynamicFvMesh.so(_ZN4Foam25dynamicMotionSolverF vMesh6updateEv+0x3e)[0x7f92aced5e7e]
[adrian:14894] [10] interFoam(+0x49134)[0x555a2d6da134]
[adrian:14894] [11] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f92aa26bb97]
[adrian:14894] [12] interFoam(+0x53a9a)[0x555a2d6e4a9a]
[adrian:14894] *** End of error message ***
mpirun noticed that process rank 0 with PID 0 on node adrian exited on signal 8 (Floating point exception).
cyberpr123 likes this.
AdrianM is offline   Reply With Quote
Old   December 2, 2019, 08:22
cyberpr123 is on a distinguished road
AdrianM,
I m facing the same issue, Did you get any solution to this? Pls help.
Thanks in advance.
cyberpr123 is offline   Reply With Quote
dtchull tutorial, sixdofrigidbodymotion
Inertial resistance term in Fluent star FLUENT 1 April 3, 2019 05:56
Inertial Resistance and Viscous Resistance Data ravitejakatragadda FLUENT 5 May 10, 2018 05:16
Viscous resistance and Pressure resistance PeiSan Fidelity CFD 2 September 22, 2014 04:35
Ship resistance tobino FLUENT 0 June 27, 2011 21:31
adapt viscous resistance based on velocity / UDF Häwimeddel FLUENT 2 April 20, 2009 11:08
