why in solve(UEqn == -fvc::grad(p)) UEqn.source() is not modified and UEqn.H() chang
Like Tree15Likes
  • 3 Post By mAlletto
  • 12 Post By mAlletto
Old   January 1, 2019, 12:26
Default why in solve(UEqn == -fvc::grad(p)) UEqn.source() is not modified and UEqn.H() chang
Michael Alletto
mAlletto will become famous soon enough
Hello Foamers,
I have a fundamental question understanding simpleFoam.
when solve(UEqn == -fvc::grad(p)); is called in simpleFoam the UEqn.source() not modified (i printed the UEqn.source() for a small cavity flow) but UEqn.H() is modified.
from the source code in fvMatrix.C this is not to see.
The operator == is defined as follows
template<class Type>
Foam::tmp<Foam::fvMatrix<Type>> Foam::operator==
    const fvMatrix<Type>& A,
    const DimensionedField<Type, volMesh>& su
    checkMethod(A, su, "==");
    tmp<fvMatrix<Type>> tC(new fvMatrix<Type>(A));
    tC.ref().source() += su.mesh().V()*su.field();
    return tC;
    const tmp<DimensionedField<Type, volMesh>>& tsu
    checkMethod(A, tsu(), "==");
    tC.ref().source() += tsu().mesh().V()*tsu().field();
    tsu.clear();
    return tC;
    const tmp<GeometricField<Type, fvPatchField, volMesh>>& tsu
    tC.ref().source() += tsu().mesh().V()*tsu().primitiveField();
    tsu.clear();
    return tC;
as far as I understood it returns a new fvMatrix with the source term modified leaving the
fvMatrix<Type>(A)) unchanged
the function solve executes fvm.solve, clears the space and returns some statistics:
Foam::SolverPerformance<Type> Foam::solve(const tmp<fvMatrix<Type>>& tfvm)
    SolverPerformance<Type> solverPerf =
        const_cast<fvMatrix<Type>&>(tfvm()).solve();
    tfvm.clear();
    return solverPerf;
From this analysis I would guess that the matrix UEqn is solved with the addition of the pressure gradient but the H operator should not be changed. This is obviously in contrast from the printing of H and source during the iteration.
What I also noticed is that the field U is also modified after calling solve(UEqn == -fvc::grad(p));
amuzeshi, Kummi and yueyun like this.
mAlletto is offline   Reply With Quote
Old   January 1, 2019, 12:59
Michael Alletto
Ok maybe I can answer my question by myself:
When the matrix
    tmp<fvVectorMatrix> tUEqn
        fvm::div(phi, U)
      + MRF.DDt(U)
      + turbulence->divDevReff(U)
        fvOptions(U)
    fvVectorMatrix& UEqn = tUEqn.ref();
is constructed the solution vector psi_ is defined as a reference to U:
Foam::fvMatrix<Type>::fvMatrix
    const GeometricField<Type, fvPatchField, volMesh>& psi,
    const dimensionSet& ds
    lduMatrix(psi.mesh()),
    psi_(psi),
    dimensions_(ds),
    source_(psi.size(), Zero),
    internalCoeffs_(psi.mesh().boundary().size()),
    boundaryCoeffs_(psi.mesh().boundary().size()),
    faceFluxCorrectionPtr_(nullptr)
    if (debug)
        InfoInFunction
            << "Constructing fvMatrix<Type> for field " << psi_.name() << endl;
    // Initialise coupling coefficients
    forAll(psi.mesh().boundary(), patchi)
        internalCoeffs_.set
            patchi,
            new Field<Type>
                psi.mesh().boundary()[patchi].size(),
                Zero
        boundaryCoeffs_.set
            patchi,
            new Field<Type>
                Zero
    // Update the boundary coefficients of psi without changing its event No.
    GeometricField<Type, fvPatchField, volMesh>& psiRef =
       const_cast<GeometricField<Type, fvPatchField, volMesh>&>(psi_);
    label currentStatePsi = psiRef.eventNo();
    psiRef.boundaryFieldRef().updateCoeffs();
    psiRef.eventNo() = currentStatePsi;
after that the function solve(UEqn == -fvc::grad(p)); is called. It indeed solves a new matrix (the old one where to the already existing source the pressure gradient is added).
But when the matrix is solved, the solution vector psi_ is modified which is a reference to U. This is in line with the observation that U is modified after the solution of the matrix.
Hence also the solution vector psi_ of UEqn is also modified. But the source of UEqn remains unchanged.
since the H() is computed from the solution vector psi_ and the source:
Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>>
Foam::fvMatrix<Type>::H() const
    tmp<GeometricField<Type, fvPatchField, volMesh>> tHphi
        new GeometricField<Type, fvPatchField, volMesh>
            IOobject
                "H("+psi_.name()+')',
                psi_.instance(),
                psi_.mesh(),
                IOobject::NO_READ,
                IOobject::NO_WRITE
            psi_.mesh(),
            dimensions_/dimVol,
            extrapolatedCalculatedFvPatchScalarField::typeName
    GeometricField<Type, fvPatchField, volMesh>& Hphi = tHphi.ref();
    // Loop over field components
    for (direction cmpt=0; cmpt<Type::nComponents; cmpt++)
        scalarField psiCmpt(psi_.primitiveField().component(cmpt));
        scalarField boundaryDiagCmpt(psi_.size(), 0.0);
        addBoundaryDiag(boundaryDiagCmpt, cmpt);
        boundaryDiagCmpt.negate();
        addCmptAvBoundaryDiag(boundaryDiagCmpt);
        Hphi.primitiveFieldRef().replace(cmpt, boundaryDiagCmpt*psiCmpt);
    Hphi.primitiveFieldRef() += lduMatrix::H(psi_.primitiveField()) + source_;
    addBoundarySource(Hphi.primitiveFieldRef());
    Hphi.primitiveFieldRef() /= psi_.mesh().V();
    Hphi.correctBoundaryConditions();
    typename Type::labelType validComponents
        psi_.mesh().template validComponents<Type>()
        if (validComponents[cmpt] == -1)
            Hphi.replace
                cmpt,
                dimensionedScalar("0", Hphi.dimensions(), 0.0)
    return tHphi;
this explains why the H() field is changed and source not
hjasak, snak, aerospaceman and 9 others like this.
