Creating a rotating plane for a fan without modelling the blades |
October 23, 2018, 00:17 |
Kevin Williams
Rep Power: 10 |
Hi all,
I am trying to run a flow simulation in a duct with a fan placed in the middle without modelling the fan blades. I have the rotational speed of the fan and the inlet velocity and was thinking if its possible to create some sort of rotating plane where the fan is positioned to simulate swirl from that region. Can someone guide me on how I should proceed? Thanks. |
November 6, 2018, 06:33 |
Kevin Williams
Rep Power: 10 |
Hi all,
Any responses would be appreciated? Thanks |
November 7, 2018, 12:40 |
#3 | |
Geir Karlsen
Rep Power: 14 |
https://www.openfoam.com/releases/op...conditions.php |
November 7, 2018, 15:43 |
Niels Nielsen
Rep Power: 27 |
Could also look at this tutorial.
I made the initial case to test the workings of the rotorDisk. https://github.com/OpenFOAM/OpenFOAM...Foam/rotorDisk https://www.openfoam.com/documentati...otor-disk.html Another way to add swirl is to use porous media. So combine the fan bc with porous media. http://www.tfd.chalmers.se/~hani/kur...ukurReport.pdf page 10 https://www.openfoam.com/documentati...-jump-fan.html
Linnemann PS. I do not do personal support, so please post in the forums. |
November 8, 2018, 04:27 |
Zander Meiring
Rep Power: 8 |
Try reading up on the actuator disk model if you want realistic simulation of the fan. It makes use of lift and drag data for the fan profile to determine the flow field that would result of the fan. It has been successfully used in applications such as modeling entire air cooled condenser systems for power plants
November 12, 2018, 01:02 |
Kevin Williams
Rep Power: 10 |
Thanks for all your responses.
I am going to try out your suggestions and keep you'll posted. |
January 16, 2019, 13:06 |
Kevin Williams
Rep Power: 10 |
Hey all so I was trying to go with the porous media modelling for the fan blades but I cannot find much documentation on the powerLaw and porosity coefficients. Let's say I know the power loss in watts across the fan (assuming I'm modelling a wind turbine) how can I define those values in 'porosity'?
January 23, 2019, 17:22 |
Kevin Williams
Rep Power: 10 |
Hello all,
Any responses? Can someone point me to some tutorial or reference material on how to setup and run the cases? Thanks |
February 14, 2019, 12:19 |
#9 |
Kevin Williams
Rep Power: 10 |
Hey all,
I managed to get the actuator disk to work. But I have a doubt regarding the upstream point in FVOptions. Can someone please explain what exactly it is since I varied the upstream point of the disk but did not notice any change in results. Thanks, Kevin |
January 18, 2021, 17:05 |
ActuationDisk
#10 |
Farzad Faraji
Rep Power: 8 |
Dear Kevin Williams
Could you please explain me briefly how did you get ActuationDisk worked? Farzad |
Rotating blades of a fan by Fluent? | guillaume1990 | FLUENT | 17 | June 22, 2016 04:01 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
Rotating blades of a fan Fluent? | guillaume1990 | ANSYS | 1 | March 21, 2014 04:15 |
fan rotating | tongnan | FLUENT | 1 | February 7, 2013 17:50 |
Help need to simulate flow around Contra rotating Fan | venkat_aero2007 | Fidelity CFD | 0 | July 31, 2012 15:01 |
