September 17, 2018, 09:55 |
Help for Overset Mesh in Openfoam
Vignesh S P
Rep Power: 8 |
I'm trying to implement overset grid for solving my problem, for floating object. can anyone point me to any tutorial or provide me with steps and explanation on how to implement overset mesh in openfoam. |
September 17, 2018, 10:38 |
Yann
Rep Power: 29 |
Hello Vignesh,
Overset is implemented in openFOAM v1706 and above (ESI branch). I would recommend the latest version (v1806) since there were some bugs in the first version. About tutorials, I think tutorials/multiphase/overInterDyMFoam/floatingBody is what you are looking for! |
September 17, 2018, 11:28 |
Vignesh S P
Rep Power: 8 |
Thank you yann
September 18, 2018, 04:29 |
Michael Alletto
Rep Power: 16 |
There is also an overset mesh version in the foam extended fork.
https://foam-extend.fsb.hr/blog/2017...n-foam-extend/ I tried it out and this version is a bit faster than the one implemented in OF1806. The concepts are a bit different. |
September 18, 2018, 10:32 |
Vignesh S P
Rep Power: 8 |
Thank you mAlletto I'll look into it
September 22, 2023, 10:18 |
overset mesh
shristi
Rep Power: 3 |
I'm trying to implement an overset grid for solving my problem, for multi-cylinder. can anyone point me to any tutorial or provide me with steps and explanation on implementing overset mesh in openfoam2206. I am facing difficulties with blochMesh for body cylinders and also facing difficulties to run the simulation. Looking forwards for your response. Thank you |
September 22, 2023, 10:30 |
Yann
Rep Power: 29 |
You can start with the documentation: https://doc.openfoam.com/2306/tools/...erics/overset/ There you will find a list of overset solvers, you can then go to the tutorials directory and explore tutorials corresponding to these solvers to find something close to what you are trying to achieve. Hope this helps, Yann |
September 22, 2023, 11:40 |
shristi
Rep Power: 3 |
thank you so much ..i will look into that...
September 24, 2023, 04:23 |
#9 |
Michael Alletto
Rep Power: 16 |
You can have a look here regarding the cylinder https://wiki.openfoam.com/Vortex_ind...ichael_Alletto
And overset. I think using the two rotor tutorial will help you to find a way to use multiple cylinders Best Michael |
openfoam, oversetmesh |
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) | Combas | SU2 | 45 | October 16, 2024 18:26 |
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM | nsf | OpenFOAM Meshing & Mesh Conversion | 86 | February 8, 2023 11:30 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 09:51 |
[Commercial meshers] converting ICEM mesh to OpenFOAM | bmikuz | OpenFOAM Meshing & Mesh Conversion | 9 | May 10, 2016 17:47 |
[Salome] Mesh conversion Salome to OpenFOAM | VMartinez | OpenFOAM Meshing & Mesh Conversion | 11 | April 21, 2014 03:54 |
